Question about Kitchen Ranges
How do I get the microwave to get off of defrost mode?
    President:
  • Kitchen Ranges Master
  • 2,080 Answers
The exact process depends on the make and model number of your unit, but normally you just set the power level back to 10.
Comment back here to this page with the model number and I will assist you further if necessary.
Good luck.
Posted on Mar 30, 2011
How do I defrost food on a matsui m150tc
read the user manual for how to do it
defrosting in a microwave is actually low level intermittent cooking so read the book
Nov 30, 2016 | Microwave Ovens
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
Kenmore microwave 721.63653300 buttons not working properly
follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2ZYTO5cC9
Jul 19, 2013 | Kenmore Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
Microwave is not heating, it seems as if is stuck in defrost mode. Two red lights are showing at the top of the microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '';
May 28, 2011 | Emerson MW8991SB Microwave Oven
When you press start the microwave starts with a low hum and sounds like a bearing or fan is vibrating, micrwave still heats up and works just runs rough. Bruce
Ther is a loose peace of metal in the magnetron, it is not a big worry, it's just noisy, i have a noisy microwave and it is working fine for 10 years now, if you use the defrosting mode you should hear the noise (on and off) because in the defrost mode the magnetron energises on and off, it could be the cabinet vibrating as well look for loose peaces of metal
Jan 04, 2011 | GE JVM1850 1000 Watts Microwave Oven
I selected defrost mode to defrost my cheese in my panasonic microwave and after that I do not know how to go back to normal mode.
No model # to reference. Find the CLEAR, CANEL or RESET button /key pad and press once or twice. If this does not correct...unplug for 5 mins, plug back in and reset clock. This should fix it.
Ric
Mar 10, 2010 | Microwave Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
