Question about Poulan Garden
My poulan chain saw starts but as soon as I start to use it to cut it shuts down. It has plenty of gas and oil, what would cause this to continue to happen? Thank you!
  • Poulan Master
  • 2,239 Answers
Sounds like it is runing too lean, remove the filter from the tank ( on the end of the fuel line ) and replace, check all the fuel hoses up to the carb, any signs of cracking or fatigue, then replace them, if no better make a small adjustment to the H scerw on the carb, screw out approx 1/4 tur.
Posted on Mar 31, 2011
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
Jul 27, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
My chainsaw poulan p3314 will run fine for about five minutes, then cuts out and wont start until it cools down....???
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
Sep 16, 2013 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
The chain saw is brand new. It starts OK but after I make one cut it stalls (Every time).
Do you have the proper gas-oil mix? It should be 40:1, which is 3.2 oz of oil/synthetic oil to 1 gallon of fresh gasoline. Make sure you push in the choke after starting it. Also make sure the chain brake is off (chain should move freely by hand when the saw is TURNED OFF.) If gas mix is right, choke is turned off after starting and brake is off, take it back to the dealer/store.
Aug 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you remove the sprocket and clutch assembly
Article: Fixing a Broken Chainsaw
Having a broken chainsaw is an inconvenience. Having one that works when you need it is important! Chainsaws are useful tools for tree pruning, cutting firewood, and carpentry projects, but are not so useful if not properly maintained. It can also cost a great deal of money to get a broken chainsaw repaired. You can save a lot of time and money by repairing it yourself. For chainsaw repair you will need a blanket or large cloth, a chainsaw tightening tool, files to sharpen the blades, and any necessary replacement parts.
My Chainsaw's Engine Does Not Start
If the engine will start at all, you might have a bad starter switch. Check to see that all connections to the starter switch are secure. Is the power cord cut or broken? Check to make sure that you have a proper power line connection. If all checks out except for the switch, go ahead and replace it. You may want to consider whether you are using the appropriate fuel mixture.
My Chainsaw Smokes
If there is smoke coming from the chain, it could be an indication that there is not enough lubrication. Without the proper lubrication, the chain and chain bar can become seriously damaged. Make sure there is oil in the reservoir. When you start the saw, the automatic oil pump should lubricate the chain and bar. To see if this is a problem, hold the saw tip over a light-colored surface, hit the throttle and look for oil spatters on the chain bar. If you see no oil splatters, turn the saw off. Remove the chain guide bar and see if the oil discharge slots are clogged with sawdust. Clean out the sawdust and restart the saw to check lubrication again.
The Chain Skips or Jumps
If the chain skips or jumps during operation, check the engine drive sprocket to make sure it is not worn. If you have a worn sprocket it will not allow the chain to sit properly. Also, check to make sure the chain tension is set correctly. Setting the chain tension is a part of continuous operation. However, a dull or damaged chain may also cause the skipping and jumping.
My Chainsaw Isn't Cutting Properly
If the saw cuts at the wrong angle or shoots out a lot of sawdust, you probably need to sharpen the chain. A dull chain can be very dangerous. It can cause a kickback or chain jump that might break the chain and release pieces that could harm to the operator. If your chain is very shiny, you need to examine each cutter for damage. Use a file to sharpen the cutters.
The Chain Continues to Move or Stops
If the chain continues to move while the engine idles then you should check to make sure the idle is not set too high. If it stops while cutting, see if the brake is engaged.
My Chainsaw Loses Power
If the saw loses power while operating, check to make sure all electrical connections are secure. Any break in current may cause the saw to decrease in power, stall or shut down altogether.
When maintained, chainsaws are a great asset to any tool collection. Consult your user's manual for questions specific to certain manufacturer types.
About the Author:
Oct 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan 3314 saw that is only two weeks old. It works good until it's warmed up for about 20 minutes. Then, when you finish a cut and get off the throttle it dies. It always starts right up again....
The low side of carb setting needs to be shut down. Will speed the idle up and stop from overloading on fuel. Only one catch. It takes a special tool to adjust. Go to poulanpro.com for your nearest dealer.
Oct 28, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 2600 chainsaw
Sounds like the chain brake may be causing it.
Oct 15, 2008 | Garden
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
