Question about Kitchen Appliances - Others
Can powercords be switched out on different brands of dishwashers?
    Genius:
  • 1,114 Answers
Theoretically as long as the can carry the same voltage then you can switch them.
Posted on Mar 30, 2011
F14 fault. What do I do?
Miele Fault Codes
Different brand dishwashers have different fault codes. That said, this may well be your brand. It does list the F14 fault code as well as the others.
Jun 03, 2017 | Dishwashers
Where is the fuse located at on acer computer
There is none.
If it is a Desktop Computer (case) you will need a new power supply or a different one to test if that is really the problem.
on a laptop, try holding the power button for ~40secs with all power diconnected (no battery and no powercord).
then re-plug the powercord to see if it will turn on. Try a different powercord if it still wont turn on, or have it tested at an electronics store.
Aug 30, 2014 | Acer Aspire Computers & Internet
Brand new Samsung Dishwasher DW7933LRA Flashing light "HEAVY" and will not start
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DMT400RHS Builtin Dishwasher
My battery is not charging in my laptop, Great Quality Brand
If the laptop is about 2 years old (can be less) then I would say your battery is dead and needs replacement. That is very common and typical of all brands.
Replacment cost is sometimes covered under warrenty so check if you are still covered. A new battery is worth $60 to $160 depending on make model and age.If you are paying for it check around as the price can really differ from place to place.
Apr 13, 2010 | Computers & Internet
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
My panosonic lcd tv has devepoped multiple bright colorspots
This is caused by magnetic fields. Either the speakers of tv is faulty or demagnatziser not working. Switch of tv and remove powercord from wallsockets. Leave for about 10 hours and plug in powercord and switch on. if demagnatiszr is working the blue will be gone. if not have youre tv demagnetized
If hometheatre or radio speakers are closer than ½ meter this could also generate coulouration of screen. move speakers further away. If tv is on and and being moved your static electricity can also cause this. So switch of if if you move your tv.
Aug 09, 2009 | Televison & Video
Food is being shot into the top rack and getting stuck inside the glasses. It is a brand new dishwasher-had it for a week. We have tried different settings on the dishwasher and different detergents
It sounds like you have a great deal of water pressure which a plumber may be able to address.
Otherwise, This may sound simplistic but it may be easier to hand rinse the dishes that have a lot of food still on them before they are placed into the dishwasher.
Good luck. :)
Apr 26, 2009 | Dishwashers
Rinse agent dispenser doesn't seem to be working
Keeping your rinse aid dispenser filled up may help, But ... By far the most common problem of white (mineral) deposits building up in a dishwasher is someone switched from a name brand to a generic, ultracheap dishwasher powder. I love store brand products and buy them all the time but when I bought an ultra cheap brand of powder detergent, within 5 loads of dishwashers the white build up showed up.
Switching back to a brand name powder like Electrosol or Cascade will really help.
The other thing you should probably do is pull the filter gear underneath the lower spray arm and clean out what ever has collected there. That is especially true is your dishwasher is making louder/different noise during the wash/rinse cycle.
Good Luck! Please report back here what you find, OK?
Apr 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Which powercord to use?
In the bottom of the laptop you can find the input required, make sure the voltage matches the requirement and the connection is the right way.
from what you said I can't tell if its too stong, can you adjust the voltage? look in the bottom it is documented there on a label.
Jan 16, 2009 | Acer Aspire 1640Z Notebook
Kitchen Appliances - Others Logo
16 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
