Question about HP Computers & Internet
On start up the monitor flickers constantly from black screen to the desktop
  • HP Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Mar 30, 2011
Why does the screen of my iMac G4 stay black on start up?
Test the system on an external monitor. If OK, replace the screen.
Jun 09, 2012 | Apple iMac G4 20" Mac Desktop
Toshiba Equium A100-02k laptop black screen
sounds like it could be the monitor itself
Apr 02, 2010 | Toshiba Equium 100 PC Desktop
When I turn my computer on the monitor constantly flickers on and off. After about an hour this stops the the screen goes black about five times, but after that it works fine?
You need to download the latest graphices drivers and get the update for the BIOS.
If the screen flickers in the BIOS screen as well that means the sys has to be repaired for the screen.
Feb 06, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Screen flickering how to change flicker rate on monitor
Control Panel
Display (or Display Properties)
Settings tab
Advanced
Monitor tab
under Screen refresh rate, change to 70 hertz or higher
Apply, black screen
(Your desktop has been reconfigured. Do you want to keep these settings?) Yes
OK
OK
Jan 29, 2010 | Samsung SyncMaster 753 DFX 17" CRT Monitor
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
PC won't turn on, blue light flickering, green light flickering
check your monitor's connection, its power and VGA connection to cpu, the cpu may be good but you just see black screen bec. your monitor remained off. please bring it to HP service center for more help
Oct 18, 2009 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
Gateway sx2800-03 compatibility problems with Samsung 2494hm
you have the wrong video driver - go to gateway and redownload the video driver and install it reboot and presto...
Aug 31, 2009 | Gateway SX2800-01 PC Desktop
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Screen flickering constantly
You don't say if it's CRT old style or a new TFT screen,either way the first port of call is to right click on a blank bit of the desktop and choose properties from the menu,you should find a section with your monitor refresh rate on it,this is usaully set to 60hz by default,75hz or above should get rid of flicker if your monitor supports higher.....failing that,have you got anything recently placed near it that could interfere with signal such as a mobile phone?.....also check cables for condition and plug is secure.......if these fail you might have a fault developing in your graphics card or if its a TFT screen an ilumination tube maybe faulty inside the screen
Apr 01, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
