Question about JVC LT-32D200 LCD TV
Jvc lt-32d200 wont turn on - JVC LT-32D200 LCD TV
  • 1 more comment
  • jose ochoa Mar 30, 2011
    i checked and change the power supply and main board already. When i press the power Buttom the front power light blinks blue and then goes to standby again
    well. i didnt order that board you sent me. i order the main board but, it makes sence, and i was suspecting that it could be this one you are pointing out. i just want it another opinion to order it and return the one i already have. i dont see any blown caps , everything looks great.
  • jose ochoa Mar 31, 2011
    i placed the order for the inverter/psu board. Ill keep you posted.
    President:
  • 2,080 Answers
First of make sure the unit is plugged into a live outlet. Test with a multimeter or a plug in reading lamp to be sure there is power there. If you have the set plugged into a power bar, try plugging the set directly into the wall outlet instead.
Next try turning the unit on with both the remote control and the power button right on the tv itself to ensure it is not just a problem with your remote control.
If you do have good power at the outlet and neither button will turn the unit on, then check to see if there are any lights at all on the front of the tv. Do they change color or flash when you plug in the tv or try to turn it on with the buttons?
Are you getting any sound from the speakers, or glow from the screen when you turn it on, or is the tv completely black and dead? You can try turning out the room lights while the tv is on to be sure there is not a faint glow from the screen.
Are you willing or capable of disassembling the tv to conduct basic electrical troubleshooting on the circuit boards and components inside the unit?
And approximately how much money would you be willing to spend to fix this unit? I only ask this because if you are unable to complete certain repairs yourself and need to bring the unit into a shop, then in some worst case scenarios, it is possible the total repair bill including labour may approach the cost of a brand new tv. However this is not always the case and some repairs are much less expensive to carry out.
Just comment back here to this page with as much of the information I requested as you can gather and I will assist you in determining the exact problem with your set and all your various options for resolving the issue.
Thank you very much.
Joe.
Posted on Mar 30, 2011
  • 1 more comment
  • Joe2
    Joe2 Mar 30, 2011
    Sorry about that, I wasn't sure of your skill level at first.
    Well, it does sound like the power supply board as you suspected, but you would have to be pretty unlucky to get a bad replacement board as well.
    I assume this is the combined power supply / inverter board that you replaced:
    http://cgi.ebay.com/JVC-LT-32D200-Pow-Su...
    One thing you can try is leaving one of the connectors from the inverter board to the backlight disconnected and then powering the unit up. Try that for each of the backlight connectors in turn to see if one of them in particular is causing the fault condition shutdown. It may not work, but if you can isolate the problem to one bad backlight bulb, then that will give you some hope at least for a successful repair. If the problem is the LCD panel itself, then you probably know already that a cost effective repair is unlikely. Keep an eye out in your local online classifieds (like Kijiji) for a malfunctioning tv of the exact same model, or even place a free ad for one yourself. Often you can pick these up really cheap, and it makes for a good source of spare parts and a possible testing platform as well.
    Here is a link to another expert's solution with a set of his excellent LCD Troubleshooting Guides which contain detailed instructions oh how to test the various components of your LCD tv. It might help you out in your own investigations.
    http://www.fixya.com/support/t8133519-no...
    Please rate his solution with a Thumbs Up if you find the information helpful.
    Good luck.
  • Joe2
    Joe2 Mar 30, 2011
    OK, just so I'm clear...
    You bought a new MAIN board and replaced it yourself but it did not help the problem.
    You did NOT change the POWER SUPPLY / INVERTER board yet.
    You visually examined the power supply / inverter board but did not find any bulging or leaking capacitors, and the original power supply / inverter board is still in the tv.
    Please confirm that this is the case.
    Also confirm the exact part numbers for the boards in your tv just to be sure. The numbers should be something like the following:
    BA94F0F0102-2-A like the following main board:
    http://cgi.ebay.com/JVC-LT-32D200-PowER-...
    and
    BA94F0F0103-2-A like the following inverter board:
    http://cgi.ebay.com/JVC-LT-32D200-Backli...
    In most cases it is something on the power supply board which fails first. Bad capacitors are often pretty obvious, but sometimes they are not. One more thing you can look for is bad surface mounted fuses on the inverter board. They look a bit like the ones at the following link:
    http://news.directindustry.com/press/lit...
    Sometimes they will look cracked or burnt if they are bad, and sometimes you can test them for continuity with a multimeter while the power is off. If you are really brave, I mean experienced, you can try testing the voltage (12V DC) on either side of them with a voltmeter while the tv power is on, but I do not normally recommend trying that for safety reasons.
    If you are going to order a new board from EBay or wherever, make sure the part numbers are IDENTICAL. Sometimes it's just the last number that's different and it will cause it not to function. Also make sure that any board you buy off EBay is listed in the description as TESTED WORKING. If the description of the board says something like AS IS, then definitely stay away from it.
    OK, good luck.
    Joe.
  • Joe2
    Joe2 Mar 31, 2011
    OK, good luck.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Is my jvc av-32d200 a digital tv
No, it is analog.
http://www.cnet.com/products/jvc-av-32d200-32-crt-tv/specs/
May 10, 2015 | JVC Televison & Video
The tv only wines and does not have any lights and the screan does not work.
the power supply failed. The sound you are hearing is from a fixed coil.
Nov 13, 2013 | JVC LT-32D200 LCD TV
Only showing blue red and black colors
It sounds like a display panel fault. Anyway make it sure. Check the site linked here. It has illustrations and details to faults to LCD display screens. Contact any service technician too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 11, 2013 | JVC LT-32D200 LCD TV
Lt-32d200
What you are describing is a bad/damaged optical unit in the player--some are sold but only as a complete unit.
Mar 20, 2012 | JVC LT-32D200 LCD TV
Jvc model no. LT-32p679. cable line was struck by lightning now tv wont turn on
Cable system is grounded to electrical system. Most electronics have fuses inside. Open it up and look for blown fuse.
Oct 13, 2010 | JVC LT-32P679 32 in. LCD TV
Hi I have a JVC 32 D200 with the DVD on the side,
It is metric screw: 4mm thread and approximately 20mm long with a washer
Jan 27, 2010 | JVC LT-32D200 LCD TV
Won't turn on
power supply problem , normaly 2 caps on power supply 1000uf 25v also check for loose connection on flyback
May 07, 2009 | Televison & Video
JVC LT-32D200 LCD TV Logo
512 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
