Question about Jackson Dishwashers
I have a commercial Jackson Omega HT, the machine just displays message "close door" even when the door is closed. i tried switching it off and putting it on, but the problem persists...the machine has stopped working completely...what do ii do?
jessee007
  • 310 Answers
SOURCE: door will not close
the eyes are a little bit out of adjustment
Posted on Jan 09, 2008
JohnnyBeans
  • 223 Answers
SOURCE: close door read out appears
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
Posted on Jun 02, 2008
SOURCE: E2 error but I did close the door
This machine is very problematic. I had the E2 Error as well. The problem, like dddd501 said, is with the spring in the left hinge of the top lid. It probably gets loose after some use. I solved this, after many trial and errors by wedging a piece of thick cardboard in the gap between the top lid and the surrounding machine in such a way as to PUSH the top lid BACKWARDS into the direction of the control panel. This, I presume, will force the spring into whatever sensor that detects the top lid is closed and removes the E2 message.
(Diagram) View of washing machine from the top: Wedge the thick cardboard at the gap marked XXX. Good luck.
_________________________________
| Control Panel |
|---------------------------------------------------------| LH = Left Hinge
| LH RH | RH = Right Hinge
| || Top Lid || |
| ||=XXX======================|| |
Posted on Sep 20, 2008
  • 1089 Answers
SOURCE: The close door message stays on my Gagia Titanium coffee machine
HI
There are 2 things that give the close door message. On the back side of the door towards the hinge, there is a pointer that activates a switch. If that pointer is broken, it won't touch the switch. Replace the door or modify the pointer to touch the switch. If the pointer is not broken, there is an adjustment inside the machine on the steam manifold mount that has 2 screws that can be loosened to move the mount forward (bringing the switch forward) so the pointer can touch the switch.
Posted on Jul 01, 2009
Affinity Dryer code E66
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
Aug 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My bizhubb c250 is displaying
open front door then push the IU correctly then close the door and close the side door from your right side...
Nov 14, 2011 | Konica Minolta bizhub C250 All-In-One...
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
When i try to start the machine, it is not starting. Message "de" is blinking. What shall I do?
Door Error: Make sure the Door / Lid is closed properly. If it doesn't help, you may need a technician to replace the Door Lock / Switch. This error is given when the door is not closed properly, or when the Door Lock / Switch is malfunctioning.
Hope it helps :-)
* If you found this solution helpful, please vote positively.
Feb 19, 2011 | LG Washing Machines
I have a Maytag front load washer. Even though the door is properly closed, the display panel displays the message "door is still open, please close". I have even tried disconnecting the...
sounds like you got a bad door switch.... make sure the door switch is actually latching and the wires are still connected.... if all is good there then the pcb controller which is the main board is bad.....
Dec 31, 2010 | Maytag Washing Machines
The close door message stays on my Gagia Titanium coffee machine even when the door is closed. I have tried reloading the factory settings but even this does not help
HI
Jun 30, 2009 | Gaggia Titanium Espresso Machine
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Close door read out appears
May 24, 2008 | Saeco Incanto Classic Espresso Machine
Dishwashers Logo
73 people viewed this question
Top Jackson Dishwashers Experts
gbob59
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
