SOURCE: how do a change the element on a candy oven ,
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
SOURCE: Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
SOURCE: element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
SOURCE: replace element in top of oven of an f241 candy cooker.
There should be two screws at the inside back of oven. However, once you have the new element look for the holes in the new one
