Question about Ronco 'Showtime' Rotisserie and BBQ Compact Model Stainless Steel
My rotisrie oven stopped working. The light turns on it looks as it is working but it does not cook. It stays cool. On Thanksgiving day we were baking our turkey and all of a suden it stopped and turned cold. I don't know how to fix it. I called the Ronco's telephone number I had and others found in the internet, but they answer that they are not in service. I don't have a mailing address either. The only description is Showtime Rotissere & BBQ, answer to fax no. 787-885-1183
2 Suggested Answers
SOURCE: need manual for a ronco showtime rotisserie &
http://www.ronco.com/rco_manuals2.aspx
Posted on Aug 07, 2010
I selected "proof" and turned the oven on this
F33 ( upper oven over temperature while cooking ) Check sensor should read 1080 ohms at room temp.
You will need to replace the oven temperature sensor. There is no quick fix for this problem to get you up and running on this Thanksgiving day, sorry. Where are you located and I will see what resources are close to you so you can make the repair?
Nov 24, 2011 | Thermador C301U Electric Single Oven
Admiral oven not heating to setting
No, I'm sorry, you will have to replace your thermostat to get this oven to heat to proper temperature. We are Admiral factory authorized parts and service professionals and will be happy to get this part out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST Monday through Saturday. If you contact us first thing Monday morning, we can next day air this to you so you can have it to cook your Thanksgiving dinner before Thanksgiving.
We look forward to working with you and hope to hear from you soon. Thanks, Ella
Nov 22, 2009 | Kitchen Ranges
Oven and broiler will not stay on.lights blink
I performed this exact same repair of a Thermador Model P366CS/03 on Thanksgiving Day 2017.
It seems a bit of grease had dripped down onto the microswitch with the sail on it. The grease was enough to prevent the switch from actuating. The thing is held down with two 4-40 screws and loose nuts. Be careful not to drop the screws into the range.
Now the problem I had was getting into the top of the stove. If the burner venturies are the least bit corroded, it's very difficult to get into the top level to gain access to the switch.
Nov 03, 2009 | Thermador PG486GEBS Stainless Steel...
Convection oven quit working half way through cooking thanksgiving stuffing
Call us right away with your brand and model number and we'll get the correct part out to you right away in time for Thanksgiving turkey!! We look forward to
working with you.
Oct 18, 2009 | Ovens
Kenmore gas oven intermittently not lighting
Replace your oven ignitor. It has to draw enough current to open the gas valve. it is only drawing enough current 85 percent of the time so the other 15 percent it wont light the oven (Gas valve wont open) The part number for the ignitor is 8190618 and is 55 bucks at sears.com
Nov 21, 2008 | Kitchen Ranges
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
MH1140XMS Oven Stays On
Right, but I wondered if you might want the OLD broken board fixed, too, as a backup? Keep it in mind, It's only $39.95.
Feb 07, 2008 | Whirlpool MH1140XMS Microwave Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Ronco 'Showtime' Rotisserie and BBQ Compact Model Stainless Steel Logo
151 people viewed this question
Top Ronco Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Ronco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
