Question about Freezers
I have a Samsung side by side fridge model RS21DPSM with ice maker. This has been working fine for three years but now the ice making tray overfills with water, which spills into the ice holding bucket below and freezes into a solid lump. Suggestions please!
  • 4,066 Answers
Your water inlet valve on the back where the water supply is connected may be sticking allowing too much water to go into the ice maker. The easiest way to see if it stops when it's supposed to is to swap the wires on the water inlet valve. Now when you press the water dispenser button the water will go to the ice maker and you can watch it to see if it cuts off immediately when you stop pushing the button. If it does then the water valve is ok and you can swap them back. If it doesn't you need to replace the water valve.
Or if that's not the problem look for an adjustment behind the plastic endcover on the ice maker with a +/- on it. - is less water.
Posted on Mar 30, 2011
Managemylife com sears
check that the ice maker is not jammed with frozen ice
dont force the tines on the tray to turn . lightly geared clock.
can you hear the little clock motor running quietly wirrs
is the water running out the front ok
is the water frozen before the tray ,defroster issue then
hit it with a hair dryier for a few mins an see what it does when u close it .
Jul 25, 2014 | Samsung RSG307AARS - 30 cu. ft. Side by...
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
hi
i had the same problem with mine,and fixed it very easily in about 10 minutes all you do is take all the shelves and draws out, then remove the light cover (one screw at the top)then the bulbs,there are three screws on this panel top middel and bottom,take these out,now gently pull the panel off,behind are two plugs unplug these and completly remove the panel.
next unscrew the water chiller at the bottom of the fridge and lay it in the botttom,take the deoderizer cartreges out and remove the two screws out from behind there,just two more screws at the bottom of the panel,there should be two plugs at the top of the panel,unplug these and remove the panel completley ,if like me you should find the fan all iced up, some warm water on a spunge should remove this and the fan should move freely if the ice is severe then remove the fan motor and run the panel under some hot water untill the ice is gone,assuming the motor is'nt burnt out this should cure it.if you want to test it plug the panel back in also the light panel ,and hold the light switch after about 30 seconds to a minute the fan should run,now just put it back together and thats it....
hope this helps
Apr 23, 2009 | Freezers
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Freezers Logo
112 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
