I have 3Q HDD External, and my usb can not see it everytime, every 5 minutes i can see it everytime...
  • 28 Answers
Hallo there, sounds like your usb bus does not have either the needed power to handle the external device and capacitors which provide could be defective, which means they are loading up and then unloading which brings a usb stop up. otherwise check your system configuration for your usb port. power usage can be defined per port on either nix systems as also on M$'s;
other option is the power supply is of cheap make and the hardware inside cant handle the power needs.
1st: check usb port power definitions,
2nd: try other port
3rd: try other power supply
P.S. sounds maybe stupid but have you tried other usb port? some of the ports provide extra power as for un-powered hdd's.
Look in the manual of your handbook as for how much power is supplied by the divers ports.
greetz
Ganimidis
Posted on Mar 30, 2011
External Hard Disk
1. External powering try changing the adaptor 2. Powered by USB try changing the USB cable 3. Try connecting to other computer 4. Check for any specific error displayed by Mac or ur PC 5. Try changing the disk name assigned to ur external HDD using disk management in PC 6. Hardware problem if under guarantee get it changed else go for data back up and solve if any bad sectors have come up in the HDD 7. You can check for software a that try to repair bad sectors in a HDD but it takes lot of patience for the same
Jan 01, 2014 | Western Digital Computers & Internet
Work around for USB Device Software for Compaq nx6110, Windows xp SP 3. my laptop some times refuse to detect and read the USB devices like : flash disk, external hard disk, modem,... it use to write that...
first off why run XP the Virus magnet?,Microsoft and hp dropped
support on this 3 years ago,,
not only that XP does not support most USB devices.
sure some old devices, but not new ones. (unless maker says otherwise and offers software to run on XP)
you are direct connected. to USB to external HDD.
That external disk, my guess has no external supply right?
that means it will overload many Latptops
the power spec, on USB varies, by different ports used and maker of the laptop...
I solve that horror by only buying external HDD what have wall power pack connected, mine is 12vdc 2amps, and will work on any PC made , ANY !
it uses its own power, so never overloads that weak PCs USB port.
here is the USB spec from WIKI page "USB" 0.5amps is gutless.
  • 0.5 A (USB 2.0)<<<<<<<<<<<<<<<<<
  • 0.9 A (USB 3.0)
  • 5 A (BC 1.2)
  • 3 A (type-C)
  • Up to 5 A (PD)
0.5 amps that is, 500mA, about 1/2 what hdd needs. to be happy.
yours is the first one, the weakest they made.
that is not enough current to spin up any HDD, from dead start.
cures: (all)
  1. get an external SSD drive,
  2. use and external case on external drive with its own powerpack
  3. buy and an EXTERNAL USB powered hub that is USB3 rated and it might run your drive connected to it.
  4. get newer laptop, one with USB 3 and runs w7 or newer.
Jun 27, 2017 | HP Computers & Internet
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I want to make an internal western digital 160GB drive from my imac g5 20" into an external drive and need to figure out what enclosure and cables i will need
You need the following
http://cgi.ebay.co.uk/External-USB-2-0-2-5-SATA-HDD-Hard-Disk-Case-Enclosure_W0QQitemZ320419271720QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item4a9a7a1428&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/3-5-IDE-Aluminum-Hard-Drive-HDD-HD-External-Enclosure_W0QQitemZ400070866376QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5d2614f5c8&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/New-3-5-USB-2-0-External-Hard-Drive-Case-HDD-Enclosure_W0QQitemZ170377549189QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item27ab4b1585&_trksid=p3286.c0.m14
Please note the links are an example only.
Sep 02, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not able to access my external hard disk
Did you check the power requirements? If the disk has external power, fine, if not, the USB power could be an issue.
You can check the USB power requirements.
Otherwise maybe this can help you:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Mar 03, 2009 | Western Digital My Book Essential Edition...
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
