The washer will not spin it just keeps going slowly and will not time down
    Brigadier General:
  • 6,277 Answers
Unfortunately you have not told us the make and model!
I would gently suggest as a first step (no promises!) that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 30, 2011
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
My amana washer barely spins but makes a jackhammer sound in spin cycle
The "jackhammer" sound is that the load (and hence, the "basket" it's in) is out of balance, causing the basket to spin in an eliptical motion.
Some washer (like mine) will momentarily shut off when it senses this, and restart when the basket slows down enough to make the out of balance condition go away, unless it starts in again, then it'll shut down again and restart.
If this is what is happening, the washer keeps shutting off and restarting, making it appear that the basket is spinning slowly, as it never gets up to full speed.
Try redistributing the load when this happens.
Also, the usually is a spring arm with a rubber "snubber" on the end that presses against the top of the basket, to help dampen an out of balance condition.
The spring over time weakens, and the dampening action is lessened.
Sep 08, 2013 | Amana Washing Machines
Washer does not go through the spin cycle
while the machine is empty and in the spin cycle open the lid and hold down the lid switch spin the basket with your hand if it spins slowly you probably have a worn out clutch.
Jul 15, 2012 | Washing Machines
Will wash clothes but not spin them dry
This is a little about how your washer spins. When time to go into a spin cycle, the motor is already running and the washer is in a pump out mode. The timer advances and closes contacts in timer that make electrical circuit through the lid switch to the spin solenoid. This is normally done through a gray wire from timer to lid switch and then a red wire from lid switch to the spin solenoid. A white common wire completes the circuit. This spin solenoid is on a magnet bar with the agitate solenoid also on it. You will see it under the machine moving back and forth as the motor runs. This magnet bar is called a wigwag in the appliance trade. When the spin solenoid is energized, it sucks a plunger pinned to the spin cam bar up into the solenoid. The plunger pin goes to a different level in the cam bar and pulls it in the direction of the motor and keeps it there until spin cycle is over. When cam bar is pulled back, it allows the clutch to drop down and engage the spinning center pulley attached to the spin tube. The spin tube turns, the wash basket is locked to spin tube, therefore it spins. Now for your question. What goes wrong?
1. The solenoid can be open. Watch it and if it doesn't **** the plunger up, check with an ohm meter. If solenoid good, assume no power to it.
2. No power to solenoid. You will need to check the circuit from timer, through lid switch, to solenoid. Most likely place seems to be lid switch. check it.
3. The wires coming to the solenoid are constantly moving back and forth as the machine runs. This puts tension on the wires and they tend to break inside the insulation of the wire. To check for break internally in the wire, read from one end of it to other with ohm meter. Another way is to grasp wire (unplug the washer) about 8 inches back from end and pull hard on end of wire. If broken inside, it will pull apart and stretch insulation. Replace wire. There are mechanical operations that can give problems, but most spin problems are in the area that I just addressed.
Another common trouble maker has cropped up in the last few years. The set screw on the clutch assembly backs out and this will keep the brake on all the time and the washer will either spin very slowly or not spin at all. Sometimes the hole in the spin tube will become damaged and requires the clutch to be replaced, but sometimes the sets screw can be reinstalled. (unplug the washer) You must remove the set screw and line up the holes by slowly turning the inner basket around. I usually use a piece of hard wire pushed into the hole, once the set screw hole and the spin tub holes are lined up you will be able to push the wire in...add some lock tight to the screw threads and reinstall the set screw. Picture of where this set screw is.
Nov 27, 2009 | Kenmore 24902 Top Load Washer
Washer will not agitate or spin
belt could be broken. If not try unplugging for two minutes, then plug back in and open and close lid seven times slowly to reset computer than runs machine.
Aug 15, 2009 | GE Profile WPRE6100G Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
GE washer spins slowly -Clothes still wet
Doesnt make any sense why the motor goes off and on. If I read your email correctly. some typos on your email. but, sounds like the belt is too big. Or the spring device that keeps the belt tight is not working properly. You need to make sure what ever it is that keeps that belt tight is working properly or not damaged. The belt is very important to making the spin work good. Match it up with your old belt. The old belt will be slightly longer because of being stretched over a period of time. Get your unit number and model number and go to your nearest dealer and get the correct belt.
Sep 18, 2006 | GE WSXH208A Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
