Question about Envision 19" Widescreen Flat Panel LCD Monitor
Contrast disabled in sRGB. How do i enable? Than
Contrast disabled in sRGB. How do i enable? Than you
Kdl-70r550a picture is dark and can't be made brighter
Auto-contrast may be enabled. Disable it in menu.
Feb 10, 2014 | Televison & Video
Contrast disabled in sRGB pop up, how to get rid of it
check settings in menu. it seems you have settings for auto instead of adjustable.
Nov 05, 2013 | Envision 19" Widescreen Flat Panel LCD...
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
I cannot adjust the brightness or the contrast. The response is just a "closed" sign and the letters sRGB.
Cannot adjust brightness cause by inverter Board problem. You can send it to computer shop or TV shop to replace it. Because the CRT and CRT TV use the same tech.
May 11, 2010 | Samsung SyncMaster 793MB 17" CRT Monitor
HOW DO YOU CONVERT NEC ASPIRE PHONES FROM FRENCH TO ENGLISH?
The keyset’s display provides a 3-line, 24 character per line alphanumeric
display that displays various information for the telephone
either while on a call or while idle. You can change the contrast of the
display as well as the language used when displaying the prompts.
1.On an idle telephone with no BGM,
or .
Pressing either volume key adjusts
the LCD display.
If BGM is enabled for the phone, in
order to change the contrast, it must
first be disabled (CALL + 825) or it will
adjust the speaker volume.
1. Press + + the language
number to be displayed (00-12).
0 = Japanese 1 = English
2 = German 3 = French
4 = Italian 5 = Spanish
6 = Dutch 7 = Portuguese
8 = Norwegian 9 = Danish
10 = Swedish 11 = Turkish
12 = Latin American Spanish
To change the
displayed language:
To adjust contrast:
58
Mar 14, 2010 | NEC DTU 8D-2 Corded Phone
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Unlocking unwanted graphics, audio
I hope these codes help
Here is a list of Secret Codes for your Samsung A707! Use at your own risk
A707 Codes
View your phone's file system *#0523# To scroll through this menu you push #
*#0842 # Vib test
*#1111# Software Version
*#2222# Hardware Version
*#1234# Firmware Version
*#0289 # Buz test
*#0228# battery profile
*#0523# lcd contrast (pretty good)
*#7465625# = Check the locks
#7465625*2827# - Auto CP lock deactivated
#7465625*28638# - Auto Network lock deactivated
#7465625*28746# - Auto SIM lock deactivated
#7465625*2877# - Auto SP lock deactivated
#7465625*28782# - Auto subset lock deactivated
Master Reset / Codes
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
*#8999*8378# - Service Menu
*#1111# S/W Version
*#2222# H/W Version
*#4777*8665# Power on attach (GPRS tool?)
*#232337# Bluetooth MAC Adress
*#7465625# = Check the locks (network, subset,etc)
*#0*# LCD Test
*#0228# Battery info
*#0289# Melody test
*#0782# Show the real time clock
*#0842# Vibration test
*#5002*8376263# Some info
Unlocking
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF LCD Test includes some speaker tests too.
Languages
If you try to access the Recent Calls from a non-English/Spanish/French language, then your phone will power cycle itself.
LANGUAGES
*#0000# - Switch to English language
*#0001# - Switch to English language
*#0030# - Switch to Greek language (90% functional) (Can't view recent calls in this language)
*#0031# - Switch to Dutch Language (90% functional) (Can't view recent calls in this language)
*#0032# - Switch to Dutch Language (90% functional) (Can't view recent calls in this language)
*#0033# - Switch to French language
*#0034# - Switch to Spanish language
*#0039# - Switch to Italian language (90% functional) (Can't view recent calls in this language)
*#0043# - Switch to German language (90% functional) (Can't view recent calls in this language)
*#0044# - Switch to English language
*#0046# - Switch to Swedish language (10% functional) (Can't do much. Makes calls. Can't view recent calls)
*#0090# - Switch to unknown language (Makes calls, can't view messages/recent calls)
*#0351# - Switch to Portuguese (85% functional) INFORMATION/TESTS
*#06# - View IMEI
*#0011# - Screen with detailed signal information.
*#0673# - MP3 Test menu MENU OPTIONS
*#30# - Caller ID is shown
*#31# - My caller ID is sent when calling
*#35# - Barring of all service/incoming calls is deactivated
*#43# - Call waiting activated
*#61# - Call forward (If no reply 30 seconds)
*#62# - Call forward (If out of reach)
*#67# - Call forward (If busy)
*#76# - "Answering number is not shown when calling"
*#77# - "My caller ID is sent when answering calls"
Dec 18, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Screen Doesn't show Transparent or High Opacity Images
Calibrate in the monitor menu the RGB values to sRGB space and disable all optimizations (movie mode, text mode...). Leave it in "Normal".
Also set carefully the contrast in the monitor to something like 60% and choose the right GAMMA in the image editing software.
Make sure you are using the native resolution of the LCD and check in the user's manual how to do the adjustments because all monitors are different.
All those settings are one-time programmable, once you got the right settings they don't need to be changed again.
Sep 21, 2006 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
What are the effects of Adobe RGB?
Adobe RGB enables more vivid color reproduction, for Adobe RGB is capable of more color space than sRGB. It offers more flexibility than sRGB on image processing and image retouching. Please note, however, a normal PC monitor cannot realize the color reproduction effect, for the available color range of the monitor is restricted by its specification. Further, an image with Adobe RGB ICC profile may be reproduced in poor color depth unless color management is provided in advance. Meanwhile, there may be cases that the Adobe RGB effect is realized in printing out, as some colors can be reproduced by a printer.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
Envision 19" Widescreen Flat Panel LCD Monitor Logo
379 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
