Question about 4003L Avital 4003 Remote Start Module (Replaces 561T)
Have a 4003 Avital remote start module installed on my 2010 Nissan Armada. It is linked to my factory key fob. Set up to start after pushing the lock button 3 times. Right now when I push the lock button three times it powers everything up and the engine will crank briefly but not enough to start the vehicle. Suggestions?
  • 5,370 Answers
The Avital remote module connection is shorting with the ignition switch or there is loose connection or shorting between starter and battery connection.Get this connections re-checked and confirmed.If any live wire connections is remained loose or not connected properly or coming in contact with any other metal part.------------check out.Keep updated .thanks.Helpmech,'
Posted on Mar 30, 2011
Keys and FOB locked inside a 2007 Nissan Armada. Why does it lock with the FOB inside? How do I get in???
How would it know the fob is inside? Call a lock service and they will use an inflatable bag to push door open just enough to unlock door.
Feb 22, 2015 | 2007 Nissan Armada SE
Have 2010 colbolt green light on fob car won't start doors won't lock or unlock
On my car you can put the fob in a little compartment inside the glove box and it will allow the car to start.
You need to "pair" the fob to the car. The procedure should be in your owners manual.
Jan 11, 2015 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Remote starts the car but doesnt unlock/lock doors
You must first get a bypass module to sync the factory with the afterm
Aug 08, 2014 | AviStart 4400 2-Way Security / Remote...
Avital 4003 with xpresskit xk09 install in a 2006 chevy silverado 2500HD gas engine. how to wire all the wires to get it working with the factory key fob.
disconnect battery remove the engine mount bolts jack up support from top remove starter and flywheel inspection cover remove mounting bolts for engine pan lower and remove oil pump suction pipe should come out then. don't forget to drain engine oil first.
Sep 12, 2013 | 4003L Avital 4003 Remote Start Module...
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
I recently had an avital 4103 remote start system installed in my 09 Chevy Silverado truck. The remote starts the truck perfectly everytime however the lock and unlock buttons dont unlock or lock everytime...
As an L1 ASE Master tech I ALWAYS advise against aftermarket alarm systems, however the problem you are experiencing is due to an action that is not being taken by the vehicles control modules. The installer should tie into the door control modules or find out why the body control module is recognizing the command for the locking/un-locking action, (hence the lighting response), but the doors are not taking appropriate action. I would have to look at live data in the vehicles control modules to see what modules are being commanded to do what. Take it back to the place where it was put in and tell them to fix it or refund it.
Nov 21, 2017 | 4103LX Remote Start System with Two...
We had the Avital 4003 keyless engine starter remote installed on our 4Runner in July when we purchased it. We shipped the car overseas and now that it has arrived the renmote will only start the radio...
You mean the igniton powers up but it does not start, correct? Sounds like the remote starter is not sending power to the starter. Did it ever work? It's possible that one of the 30amp fuses (one that supplies power to the starter output of the remote starter) is blown. If there is 12 volts present, check for voltage at the starter wire (purple) from the remote starter. If it has voltage,make sure it's connected. Also make sure that the harnesses of the remote starter are completely plugged into the module.
Sep 26, 2010 | 4003L Avital 4003 Remote Start Module...
Avital 4100 remote start in 2000 pathfinder. worked fine. went to dealer for recall of fuel filler tube. while there had new key cut and programmed. the next morning the battery was dead. after jumping the...
if your key has a blue square where the metal meets the plastic on the key, you will need to reprogram the data module used to bypass the theft system, or remove the spare key that is installed and have the dealer reprogram it
Aug 09, 2010 | Nissan Vehicle Parts & Accessories
4003L Avital 4003 Remote Start Module (Replaces 561T) Logo
181 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
