Question about Polaroid FLM-323B Television
Will a 860-AZ0-MLT666AMH power supply work in a flm-323b polaroid tv? The H is the only thing that does not match my original board. I ordered the above board online and want to try but do not want to blow it or the tv up.
  • Russell Rambat Mar 30, 2011
    Thanks Drew,
    I should recieve the board I ordered in a day or so. I will review the connections as you described then, thanks
  • 325 Answers
Ensure that all pins match perfectly before powering up the tv. Place the old board next to the new and varify that all pins (EX: 12v 24v 5v etc etc) are in the exact same locations for the quick connectors. Even with the H on the end...you probably have the newer "verison" board, but this doesn't imply that the boards are identical. With revisons you sometimes see components that are different, but pins that are the same, or you see pin changes.
I have highlighted the areas in yellow to pay attention to. See how they are stamped with the VOLTAGE read-out? These MUST match for the tv to function.
Sometimes a revision will also change the input plug for the 120v input (left yellow) check this also.
Hope this helps :)
Posted on Mar 30, 2011
  • Andrew P.
    Andrew P. Mar 30, 2011
    Never a problem. This will be the only possible issue you will run into.
    Please rate if this worked well for you. :)
Polaroid model 3211tlxb sept. 2007.ec18 on the power board gets very hot and tv shuts down. i have replaced ec18 and q16 no help
Hi mrdink010,
I've checked my service manual collection but I don't have the copy on this model. I've also search it online and to my links of the service manual but I can't find one to view the schematic diagram of your unit.
The power supply gone to excessive heat due to over current flowing on its circuitry. This is caused by faulty parts like the transistor, IC's, diode, resistor, capacitors, transformer on its line that in most cases have a partial leak. This is hard to diagnose and needs the skills of an expert to determine which part gone bad. Usually this is not caused by one parts only but most of the time multiple parts gone to malfunction.
I would advice you to replaced the entire power supply board rather than troubleshoot this kind of symptoms because it will cost almost the same. Click this LINK(http://www.shopjimmy.com/polaroid-860-az0-mlt666amh-power-supply.htm) for the replacement. Double check the actual part no. of your board that is printed on the white sticker on the board itself before ordering online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 29, 2011 | Polaroid Televison & Video
Polaroid 860-AZ0-GF371H Power Supply Unit. After replaceing all bad caps and and shorted fets Q102,103 I still need to know the value of smd zener ZK2 in Parallel with 3 low value smd resistors. I think...
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Aug 26, 2011 | Polaroid FLM-3232 Television
Element electronics tv model # flx - 2611b bad
Try ShopJimmy.com - they have a huge stock of TV parts. They are used but tested meaning they are usually much cheaper option and often have parts that are no longer available.
Power board: (verify correct part before ordering)
Picture of above part:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj860az0mlt666amh.jpg
List of available parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=element+2611&stock=all
You should verify the part number from your original board before ordering and also visually check that the replacement part matches your original. The part number is usually on a barcode sticker on the board or printed on the board itself. Be careful here as the number on the board may be the board number so try the find a part number if possible - the same board can be used for various configurations of components so is not a guarantee of being the correct part. Also manufacturers sometimes use different boards in televisions with the same model number according to price/availabilty/reliability.
You can also verify stock, part number, etc by contacting the supplier first. They may also be able to help you if you can't find your part on their website.
http://www.shopjimmy.com/contacts
Alternatively, once you have identified the part number, search for other suppliers by entering the part number into Google or Google Product Search. Be sure to enter the part number with any hyphens, spaces or periods as it is written on the board and if you have no success, also try the same search without any punctuation, e.g just the numbers and letters with no spaces.
http://www.google.com/products
Hope this helps.
Regards,
BElectric
Nov 25, 2010 | Televison & Video
Where to buy power supply for flm 323b
try finding a service center that repairs those sets. Or try ebay. Lots of TV parts there.
May 06, 2010 | Polaroid FLM-323B Television
If anyone is in need of Polaroid lcd tv parts contact me
Do you have any power supply boards left for a TDA03211C?
Sep 09, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid FLM-323B nothing at all
Check and replace ALL high value electrolytic capacitors on the power supply board. The Polaroids have known issues with leaky caps in the power supply. It's best to just change them all to prevent future failures.
Nov 10, 2008 | Polaroid FLM-323B Television
FLM-323B 3200
Check the fuse first next to the cord on the TV
Aug 22, 2008 | Polaroid FLM-323B Television
MY POLAROID FLM 323B LCD TV
many things cause black pix ,
start with loose plug on power supply ..
Aug 03, 2008 | Polaroid FLM-323B Television
Polaroid FLM-323B Television Logo
132 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
