Question about Hadco Hardware & Accessories
Where can i download a user manual for a TRAC TPE 20 central heating timer control unit
2 Suggested Answers
  • 127 Answers
SOURCE: Need user instructions for a Grasslin iht d120
Took a little hunting but managed to find it for you.
Here's the link to the manual including programming instructions.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/km2st-2d%20-%20english.ashx
Have a great day
Jim
Posted on Dec 29, 2010
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Getingcodef71onwasherwasherwillnotstart
An F71 error indicates that the control panel (the buttons you press) is not communicating with the central control unit. Open the panel and check if there is continuity to the control panel wiring harness. Make sure that the wiring harness is fully connected to the user interface panel and the central control unit. Depending on if the drum rotates, you need to replace the user interface or the central control unit. (If the drum rotates, then it's probably the user interface. Otherwise it's the central control unit.)
Whirlpool has the parts diagram for the GHW9150P on their site in the Manuals and Literature section. The direct link to the parts list for the GHW9150PW0 is: https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180440.pdf . For other models, enter the model number and click search on this page: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . This site has the parts for the GHW9150PW0: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136839&diagram_id=28192106 . If you have a different model, start here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ghw9150p .
I hope this helps.
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
When using dryer it stops and f70 shows up as problem id not listed in manual dori@dkcompanyinc.com
F70
Interface.
I have reseated the cable between the CCU and the User Interface panel (panel has the buttons & lights on it)
Mar 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he3t
maybe a false code if so may mean new control bd ..tech sheet is behind bottom panel with all fault codes if not on there code is a glitch in control
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Hardware & Accessories Logo
654 people viewed this question
Top Hadco Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hadco Hardware and Accessory Expert? Answer questions, earn points and help others
