Question about Balboa Instruments Duplex Digital Panel 2 Pump
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
    Scholar:
  • 46 Answers
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Posted on Sep 09, 2011
I have a Jacuzzi spa with a Balboa R576 (522205) control box. The control panel constantly shows "OH" (overheating) even when the water temp is 50-100 degrees F. When I reset the system by flipping the...
There are some things to check.
Make sure the vents on your cabinet are not obstructed.
Make sure your filter cycle is not too long
Make sure you are not running high speed for more then 30 mins.
Have you looked through the Balboa error message site. I have attached a link follow your error through and you may find your answer. Diagnostic Messages
Mar 02, 2015 | Balboa BB58048 Jacuzzi R574 R576, 4.0KW,...
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Spa pumps are running but display is not lit and nothing I touch on the controls work
This means your top side control is dead, the spa will continue to operate itself in an economy/maintenance mode to prevent damage.
Nov 19, 2012 | Balboa Instruments Duplex Digital Panel 2...
What is the difference between a Balboa VS500Z and a VS501Z
The Balboa VS500Z supports one two speed pump, an ozone, and 12v spa light and an optional circulation pump.
Whereas the VS501Z will support a two speed pump, a single speed pump or blower, an ozone, a 12v spa light and an optional circulation pump.
Basically the two are very similar except that the 501Z will support an additional one speed pump or blower.
The best suggestion if you are doing a replacement is to purchase one of the Value Pack Retrofit Kits available through Balboa. You basically get everything you need for the replacement, including the topside, cables, and overlay.
You can find everything you need to know about making the replacement on the following page:
BALBOA VALUE PACK VS RETROFIT KIT
Hope that helps!
Jul 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
Upper control panel flickers and will not allow me to control temo
how old is spa?
if new then circuit board maybe set on a mode setting that is used when being tested in the factory, locate dipswitch block on circuit board and move dip switch for MODE, should have a layout of dip switches on reverse of lid to control box
if older then you may need a new control panel (top side)
Adam Miller, Canadian Spa Company, UK
Aug 06, 2010 | Balboa Instruments Duplex Digital Panel 2...
My hot tub is getting power but I cannot get anything to run
you may have a circuit board error that is not allowing you to operate the controls or the top side may need replacing.
try locating the back up battery on circuit board and resetting it to restart your memory, does not always work but worth a try.
normally a J45 jumper, is marked on circuit board
Jun 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
Just purchest a balboa calafornian worket for two days then started triping i am in the uk is there any difrence in suply
your electrician should be able to advise you on this.
unplug each plug from control box and run to see if spa works, if not then a service engineer would be best to have a look and advise
Jun 14, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have a balboa 8 man spa. We shut it off to drain and clean. When we were done it would not turn back on. Tub was working fine, but now it keeps tripping the gfi. After some trouble shooting. I got it to...
YES it is the heater that is at fault.
you have 2 white water pipes that attach to heater that will need to be unscrewed (best to do with spa empty) and it depends on what control system you as to advise on heater removal. some heaters have pressure switches and others have 2x sensors or they may have both. also your heater will be held into place by brackets that are normally 8mm
Adam Mill, Canadian Spa Company, UK
May 31, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Jun 07, 2009 | Balboa Instruments Duplex Digital Panel 2...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
439 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
