Question about TruTech PVS12701 Portable DVD Player
Need a battery for the remote. - TruTech PVS12701 Portable DVD Player
  • 11,896 Answers
You can get one from etech,com or amazon,com or ebay, or partstore,com
Posted on Mar 30, 2011
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
Tip
Dyson Cool fans and Hot + Cool heaters - Replacing the remote battery (Non-screw...
How to replace the battery in your Dyson Cool fan or Hot + Cool™ heater's remote. This applies to remotes which include a push-fit base.
If your remote control's signal range deteriorates, you made need to replace your remote's battery. Press the end of the remote to release the battery. Please use battery type CR 2032.
Do not install backwards or short circuit the batteries. Do not attempt to dismantle or charge the batteries. Keep away from fire. Follow battery manufacturers' instructions when installing new batteries.
on Nov 27, 2014 | Dyson Dryers
Tip
Viper remote not charging or no display
This is for the two way pager style remotes. If the remote no longer charges or it does not display anything then it could use a new rechargeable battery. This is usually the case for 9 out of 10 problems. This battery is much like the one in your cell phone and has a chargeable life. Over time and charging it gets weaker. Also if you leave the remote uncharged for a very long time there is a good chance the battery will not recharge. If you need to go on vacation for a very long time, charge the remote and then disconnect the battery from the remote. It takes about one minute after you reconnect the battery too the remote for it to start back up. This does nothing to the pairing of the remote or system, the remote saves all of that info in it and does not require battery power to keep it saved. Here is a website to purchase new batteries viperremotebattery.com and a youtube video how to change it. http://www.youtube.com/watch?v=GGnG5iCX09A Thanks, Hopefully I can help someone in need because these remotes are very expensive.
on Mar 28, 2014 | Viper Televison & Video
I just purchased a XRT503 vizio remote for my TV and I can'tfigure out how to put the batteries in, no manual came with it
Flip remote over and see if there is a small sliding door on the back that you can slide open for the batteries. Either AA or AAA batteries needed.
Dec 02, 2014 | Vizio Remote Control XRT503 With BLUETOOTH
Wii remote not working
Have you ever used batteries in your wii remote because as soon as you put normal batteries in the wii remote instead of charging the rechargeable batteries that come with the remote then you have to use batteries. I have done this now i need to use AA batteries in my remote. If you haven't and you just have the battery pack then make sure to see if it charges on them charging things and if it don't charge then you need to take it to a repair shop. Hope this helped :)
Nov 16, 2012 | Nintendo Wii Remote Controller
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
Just need a battery, where do I get one. My remote is only 2 years old, is it common to need a new battery?
Most remote batteries will last 6 months to a year for an LCD remote or a year to 2 years for a standard 1 way remote. They're common batteries that can be found pretty much anyway. Most 2 Way LCD remotes use a AAA battery and a lot of 1 way remotes use the "coin" style batteries such as a CR2027, CR2032 etc... These can easily be found and most retail stores and drug stores. Look by the hearing aid and watch batteries. Just match it up with the battery you have in there now. If the remote doesn't have a sliding cover, then use a small flat head screwdriver and look along the seam of the remote for a small notch made for popping the remote apart for battery access.
Nov 17, 2010 | Prestige Remote Start
Remote for Sony vcr works intermittently.
Sounds like the connections inside the remote are damaged and might need soldering. Check the connections around where the battery terminals are carefully. Has a battery leaked in the remote?
Jan 28, 2010 | Sony SLV-N500 VHS VCR
Where can I order (on line) a battery for the MX 3000 remote?
I had several batteries that I ordered and they have been all purchased. Since I make no money on the batteries and can only order in bulk I will only order them if I can round up over 50 customers who need MX-3000 batteries. If you need one, please go to www.totalcontrolremotes.com and get in touch with us by putting "MX-3000 battery needed" and we will add you to the list. Either way wil let you know by mid-March 09 if and when the order will be placed for additional batteries.
Feb 24, 2009 | Universal Remote Control MX-3000 LCD...
Key remote battery replacement
Make sure that you have the Batteries Installed Correctly. If these Remotes take the Flat Round Batteries, Look and see if it tells you inside the Remote which way to Put the + On the Battery. Most of them have the + at the Top during Install. If it takes the Small Regular Battery, Looks like a Smaller AAA. You will need to Push the Connectors in a Bit Before you Install the Battery to make Sure that It connects with Both ends. Please Rate my Response, I need all the Help that I can Get! Thanks!
Jan 26, 2009 | 2005 Suzuki Swift
TruTech PVS12701 Portable DVD Player Logo
35 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
