Question about Texas Instruments TI-30XA Calculator
How do i raise an a number by a fraction exponent
    Scholar:
  • 58 Answers
Use the 'y^x' key in the upper right corner. Enter the number, then [y^x], then the exponent.
Posted on Mar 30, 2011
How do I compute fractional exponents on the TI BA II Plus calculator?
The same way you raise a number to a non-fractional power, using the y^x button. For your example, press
3 y^x ( 1 / 1 2 ) =
or
3 y^x 1 2 1/x =
Dec 08, 2012 | Texas Instruments BA-II Plus Calculator
Exponent function keys
Which exponent function?
To enter an exponent of ten, use 2nd [EE].
To raise ten to an exponent, use 2nd [10^x].
To raise e to an exponent, use 2nd [e^x].
To raise an arbitrary number to an exponent, use ^.
Feb 23, 2012 | Texas Instruments TI-84 Plus Calculator
I need help...i dont know how to put in exponents, negative exponents and i dont know how to put in fractions
For negative numbers (not just exponents), make sure you use the (-) key just to the right of the decimal point key, not the - key for subtraction.
For what follows I'm going to assume you have at least version 2.53 of the operating system for the 84Plus. If you have an older version, I STRONGLY recommend you update it:
http://education.ti.com/educationportal/sites/US/productDetail/us_os_84plus.html
You can use the "n/d" command in the MATH/NUM menu to enter the division bar. For example, to enter 1/2, press 1 MATH right-arrow ALPHA [D] 2 ENTER. If you just want the number, you can also enter it as 1 / 2.
You can convert a decimal number to a fraction using the >Frac command in the MATH menu. For example, to convert 0.2 to a fraction, press . 2 MATH 1 ENTER.
Mar 16, 2011 | Texas Instruments TI-84 Plus Silver...
Whenever I type in a negative number raised to an exponent, the calculator outputs a negative number! even for a question like -2^2. How do I fix this?
You're not raising a negative number to an exponent, you're negating a number raised to an exponent.
If you want to raise -2 to the second power, you need to enter it as
( (-) 2 ) ^ 2
Without the parens, what you're getting is the equivalent of -(2^x)
Sep 19, 2010 | Texas Instruments TI-84 Plus Calculator
Want to know how to calculate a number raised to a power
Use the general power key marked with X to the y ( look for the image of a key on same line as Power in the screen capture)
You enter a number then press the power key and finally the exponent. If exponent is complicated (fraction, negative or other) enclose the exponent in parentheses.
You aslo have dedicated keys for certain powers and roots (square, square rooot, cube, cubic root)
Jun 09, 2010 | Casio FX-260 Calculator
How to use the exponent key on a casio fx 300ES calculator ?
The key to use for the square, and the cube are well marked and they share the same physical key (X to 2) or [SHIFT][X to 2]. Similarly the keys to use for the square root and the cube root share the same physical location (the square root key, to the right of the square key).
For any other exponent, including fractions and negative exponents you use the universal power key labeled [X to ] ( X with a raised square).
  1. You enter the base (the number to be raised to a power).
  2. You press the [X to ] power key.
  3. You close the parenthesis (the right one).
  4. You press [=]
Sometimes the result may not be displayed as a decimal number, but as a radical (if you take a root). To make sure it is displayed as a decimal number, in step 4 above, press [SHIFT][=]
Mar 13, 2010 | Casio FX-300W Plus Calculator
How do I raise a number to a power other than 2?
You have the [X to the 3] for the cube and the [Y to the x] for any exponent: (positive, negative, or a fraction).
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-30XA Calculator
How to use negative exponents on a calculator?
Uh yes it will allow you to enter a negative exponent.... press the numbers you want then hit EXP button, then hit the +/- button and then the exponent. 60 % of the time, it works...... everytime.
Sep 20, 2009 | Texas Instruments TI-83 Plus Calculator
How do you square a fraction with a negative number like (3/4)^-2
Place both the base and the exponent in parentheses
(3/4)^(-2) then press enter. Your answer will be in decimal form at first 1.777...
Press MATH
Select the 1: Fraction option and it will convert your decimal value to the fraction answer of 16/9.
Negative exponents flip the fraction. For instance, (3/4)^(-1) = 4/3. So for (3/4)^(-2) you could just square the numerator and denominator separately to get 9/16, and then flip the fraction to account for the negative. That will give you 16/9.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-30XA Calculator Logo
119 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
