Question about Toshiba Computers & Internet
I cannot connect to wireless on my c650 - Toshiba Computers & Internet
    Scholar:
  • 24 Answers
I have also faced the same issues which you are facing and my friend told me about "ijinni technician". I contacted them at www. ijinni. Com. For any issues just open the website and you can chat with the experts who are Microsoft certified technicians and will fix the issue itself on the spot or u can call them through Skype. For more visit their website as it is very user friendly website. Just click on the chat as the response rate will be very fast from them and they have fixed my issues in no time.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just click on skype icon on "ijinni.com" to make a free call.
3. You can email at support@ijinni.com
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call IJINNI
Posted on Mar 30, 2011
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Weider club C650 assembly manual
There are multiples versions of the Club c650 - check your model number. Here is a user manual for the WEBE37340 CLUB C650.It comes with assembly instructions.
Here is one for the WEBE37770, but it doesn't look like it's in stock.
Apr 04, 2012 | WEIDERFITNESS.COM Weider Club C650 Smith...
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
How to take shell off toshiba c655-s5049, i need to reset mother board
Pictorial disassembly guide for the Toshiba Satellite C655 and C650 series of Notebook PCs,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
You can click on each photo one at a time, to enlarge.
Advisement:
1) Observe Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
I suggest you buy, and wear an ESD wrist strap, and connect it's alligator clip to a good ground source.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
If your table you're working on has metal legs, connect to an unpainted surface on one of them.
Barring none of the above applies, at least place a large metallic unpainted object on the table, and connect to it.
Perhaps a metal serving tray, or metal (Unpainted) knickknack.
2) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, use a clean egg carton.
label each egg holder.
Some screws look VERY similar to other screws.
Do Not mix them up.
What do you mean by reset motherboard? If your thinking is that you are going to remove the CMOS battery for a while, then reinstall it to clear a BIOS password, this = no.
There is a capacitor on the motherboard which keeps enough residual power, so that the BIOS password stays in play, even with the CMOS battery removed.
(The CMOS battery is referred to as the RTC Battery. Real Time Clock battery.
As soon as the Keyboard is removed, it is right there on the motherboard. Uses the same battery holder as a desktop computer, and it looks to be a CR2032, just like a desktop CMOS battery )
There are two pads which are shorted across briefly, with a small flat tip screwdriver.
Usually rectangular in shape, and each approximately the size of a BB.
This drains the residual power from the capacitor.
Location? Dunno
Generally under a small piece of Mylar plastic sheet, and sometimes under the Ram Memory modules, or under the wireless module.
Also, this link has a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the Toshiba main heading scroll down to the subheading that begins with -
Satellite A10.
Go to the second line in this 'paragraph', and scroll across to C650.
Left-click on C650.
(You may also want to take a look at C655D)
After you click on the file name C650, it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
Regards,
joecoolvette
Oct 11, 2011 | Toshiba Computers & Internet
To whom it may concern. I would like to know the size of the Eco Drive Citizen C650 watch. Thanks.
There is not enough information given. Citizen is make. Eco Drive is patented micro electric system name. C650 is caliber number. C650 is fitted in to many Citizen watch models. Give us exact model name, numbers, serial, etc. - then we can give the size. For a while you can check out C650 here: http://www.citizenwatch.com/COA/English/settingsresults.asp?caliber=c650 Citizen watches here;
Feb 27, 2011 | Watches
I lost my motorola c650 installation cd how cn i
Hey welcome to fixya. Hope u 'll be fine
You can easily download driver of motorola c650
  • To download the driver just "Click Here"
  • Install it on your PC and Enjoy
Wish u good luck
If it is helpful do Rate me.
Keep using fixya
Thanks
Note: if u want to download PC suit for motorlla handsets tools just follow this link
Feb 08, 2010 | Motorola Mobility C650
How can we transfer pictures from my C650 to computer?
Alternative to USB connection/picture transfer for a Motorola C650 to a PC would be:
Memory Card Reader;
Bluetooth;
InfraRed;
Wireless Networking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 23, 2008 | Motorola Mobility C650
Motorola c650
download P2K tools software which is compatible for all motorola phones... it is having in built drivers also so install the driver by giving the location where the p2k tools is located in that select folder "drv" ... this folder have all drivers when u connect your cell through cable just install this... then u can upload or download anything from pc to cell & vice versa & you can flash the cell by using the flex option....
you flash the cell even when it is turned off from this software ..
it is available in this website
www.e398mod.com/content/view/165/28/
rate my solution
Feb 20, 2008 | Motorola Mobility C650
Motorola C650 Cellular Phone
where i can download free driver c650
Dec 11, 2007 | Motorola Mobility C650
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
