Ethernet portal on pc -does not light when powered on no communication from pc to modem/router or straight to monitor
    Scholar:
  • 72 Answers
Two possibilities:
1) Your BIOS is not configured properly, in which case you would need to enter your CMOS setup at boot (usually by pressing the DELETE key, F2, or another key), and enabling the ethernet port.
2) If that is not the problem, your ethernet port has failed, and you would have to replace the motherboard.
Posted on Mar 30, 2011
Haw can i install Belkin wireless router N300 without the CD
1- Let us connect a modem to the WAN or through a port of a modem of a Belkin router.
2- Now plug into a modem & a router with a power source
3- After that it requires your PC system with any one of its LAN or an Ethernet port of a Belkin router. Remember, if a user is connecting as wirelessly then it first need to connect via the Ethernet Cable.
4- At last, in the upper panel of a device. Customer can easily observe the LED light of your Belkin router. Need to wait for 10-15 minutes for turning the LED light into totally solid blue.
5- Verify the Belkin router connections are properly connected to a modem and an Ethernet cable.
6- Now power cycle the modem by getting unplugging it through the power point and then again wait for a while. After a 15-20 minutes, plugged it back to its power source.
7- Power cycle helps a user to re-connect or established the strong communication with a modem and a Belkin router. Thus, the method is now completed for how do I setup a Belkin Router without CD.
for more checkout...
How to Setup Belkin router Install Belkin Wireless router
Apr 10, 2012 | Belkin F5D7234-4 Router
Power light blinking and all the ethernet and internet light on but my att motorola moderm and router not communicating.
it seems that your equipment is not synchronizing, have you tried to sequential power cycle ? turn off all your equipment, MODEM, ROUTER, AND PC. then turn on your modem first, after all the lights settled in, turn on the router, then after 10sec your desktop.
Jul 29, 2011 | Linksys Wireless-G WRT54G Router
Modem light is blank on motorola wr850g, how do i fix?
If the modem light is not turning ON,
1) check if the modem is ON
2) check if the ethernet connection is properly made
3) check if the port on the modem is working, confirm it by connecting it straight to the computer.
4) check if the ethernet cable is working fine.
5) Then try power cycling the router. Unplug the power cable and connect in back after 20-30 secs.
6) Then try pressing and holding the reset for 20 secs.
7) Finally connect a single ethernet cable from any LAN port to WAN port and check if the modem light is ON.
Ultimately, if even after this step, if the light doesn't turn up, either the modem LED would have gone bad or the WAN part of the router would have gone bad.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
Sep 29, 2010 | Arris WR850G Router (DHWR850G)
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
1. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
2. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
3. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
4. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
May 11, 2010 | 2wire (1000-400108-001) Router
How to change password
1. Step 1
Position your Belkin wireless G router.
2. Step 2
3. Step 3
4. Step 4
5. Step 5
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
How do i set up without the installation cd
Try this after you've pressed the small reset button on your router follow this procedure:
  1. Turn off your modem, routers, computer, and wifi receivers, and laptops and printers on the network.
  2. Connect the Wifi router with an internet cable to the modem. The router will have an internet input port (ethernet) that should be labeled differrent than the rest of the ethernet ports on the router. Plug the ethernet into the internet or modem port on the router, and to the modem...DON'T TURN THE MODEM ON YET.
  3. Turn your router's power on and let it cycle up.
  4. Then after the router is up, turn on your modem and let it cycle up. It will find your router as the main MAC address and this will establish communication between router and the internet via modem.
  5. After your modem is cycled and all lights are correct, you can turn on any computer, printer etc... and the router will assign MAC addresses to your printer etc while maintaining a proper internet connection.
that's all you should need...Since you already have a working modem to pc... remember this "firing order" and if you have a power outage or have to move again, you'll be good to go.
Dec 07, 2009 | NetGear RangeMax WPN824 Router
I cannot get my comcast supplied modem to communicate with my netgear wireless router wpn824 v2. I have tried to power cycle and that has not worked. I powered everything down to clean up the cables and...
Hi, Follow the steps below to reset and configure the router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 18, 2009 | NetGear RangeMax WPN824 Router
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration...
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
RECONFIGURE:
2. Access the router, usually with http://192.168.0.1
5. Click Apply.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Can't connect to internet after resetting router.
Try to connect your PC straight to the cable modem and see if the problem persists. If so, the modem is the problem.
You might have to reset your modem.
Unplug your router (power and ethernet to modem), unplug the power of the modem and wait 20 seconds. Plug the power back into the modem and wait until all lights are on. (This sometimes takes a minute or so.) Then plug in a cable into the modem FIRST and THEN into the router.
Now connect the PC to the router and see if you can get internet access.
If not, check your PC settings. It should obtain the IP address and DNS automatically.
If this doesn't help, please supply more information on what modem you are using.
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
