Question about Frymaster Dean GF14-SD Deep Fryer
Fryer burners turn off . have to tap on thermostat to get back on
  • Frymaster Dean Expert
  • 683 Answers
Replace the thermostat.
Posted on Mar 31, 2011
The fryer burners and pilot works fine but when I try to turn it off by the thermostat the fires go down a little but won't cut off, what could cause this
Likely one of two things. The thermostat is stuck on or your gas valve is bad. Identify one of the wires going to the thermostat and disconnect it, if the burners shut off with the thermostat disconnected the problem is the thermostat, otherwise it will be the gas valve. All this assumes the unit is wired correctly and has not been changed. If your burners are not shutting off due to a bad gas valve or thermostat you are at risk to have a fire! Be sure to get this fixed immediately and it is unsafe to operate the fryer until repaired.
Mar 20, 2013 | Frymaster Dean Kitchen Appliances - Others
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
What are most common problems found with pitco frialator fryers?
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
Feb 09, 2011 | Pitco Frialator SG14 Deep Fryer
Fryer lights off, but won't turn off when the thermostat is turned to the off position
The pilot flame will stay lighted even when the thermostat is off, you have to turn the gas valve knob to off position in order to shut the pilot flame.
But when burner flame remains on after shutting off the thermostat, the thermostat's mechanical contacts are shorted or remained engaged. If this is tha case, you have to replace the thermostat.
Jan 21, 2011 | Pitco Frialator SG18S Deep Fryer
I got problem with my cecilware gas deep fryer fms 40, i was able to turn on the pilot, then i turn it to full on possition, but the fire will go out when i was trying to adjust the thermostat, please...
Make sure the flame is staying on the burner and not lifting away from any sensors in the flame. You may need to adjust the air bands on the burners to get the flame to stay down. Also make sure the vent in the back is free of blockage.
Feb 13, 2010 | Cecilware FMS-40 Deep Fryer
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Fryer coming on without turning thermostat on
Imperial Model: IFS-40.
The thermostat is either very far out of calibration or has failed, either case it should be relplaced. The Imperial Part # for the thermostat is 1175.
May 04, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Thermostat Issue DCS Fryer??
This sounds to me like the thermostat is not sensing and is reading a closed circuit all the time. You will probably need to replace the thermostat.
Thanks
Zerko
Aug 01, 2008 | DCS FSF-75 Deep Fryer
Garland deep fryer
gas valve not fully turned on
cattering hose not fully pushed into connector
thermostat tube inside oven broken (new valve)
Nov 13, 2007 | Garland AF-5025 Deep Fryer
Frymaster Dean GF14-SD Deep Fryer Logo
80 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
