Question about Cisco Lynksys Dual Band Wireless N Gigabit Router (745883589012)
I have a lynksys router. It will work with our mac, but if i try to get online with my pc, neiter will connect or if one is connected, it will disconnect. can i fix this
    Guru:
  • 868 Answers
I see that you are having issues with your network connection, I believe that you are trying to connect wireless on both systems.
* Check your Linksys for settings that limit the routers wireless connection, most wireless routers have an option on how many computers can connect wireless to the router, a wireless signal does not chose what OS to allow for a wireless connection.
* get in your Linksys Routers Setting page from IE or Firefox using your Default gateway IP from there on you can check your Routers settings, user name depends if your internet service provider changed the Routers user name and password but for a Linksys try admin / password or admin / admin for the User name and Password field.
Hope this helps you thanks and have a good day.
Posted on Mar 30, 2011
Trying to add my MacPro to my lynksys network.
if your linksys is set for dhcp,make sure your mac is set for dhcp.
if everything is set and problem still persists,reset the linksys.
Oct 27, 2012 | Linksys Lynksys Etherfast 16-port Ethernet...
Cannot connect to the internet via Lynksis router connected to Comcast Modem.
enter the MAC address from the blu-ray player (should be in the main menu under connections) to your router in the wireless settings
Oct 11, 2009 | Panasonic DMP-BD80K Blu-ray/DVD Player
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
HOW DO I GET INTO MY LYNKSYS WIRELESS ROUTER
hi dear connet you router to pc and ping 192.168.1.1
you can mac address in the command promt
Thank you
Imrna
Pls rank me as possible have nice day
Apr 21, 2009 | Computers & Internet
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
I'm having trouble linkingto the internet from my Computer, whihc is connected wirelessly with a USB Adapter from Lynksis Compact Wireless- G USB Adapter. Basically it connects fine with my router, which...
Double check your router settings to make sure your USB wireless adapter is permitted to use your wireless connection. You will probably find this under wireless security settings. I set up my wireless routers to only allow mac addresses of devices I specify, to prevent drive-by or neighbors using my connection.
Dec 26, 2008 | Computers & Internet
Lynksys Connectivity Problem
occassionally, the wireless router needs to be turned off and on. The are some issues with regards to the stabitlity of these entry level wireless routers. What I do is put a timer at the outlet to reset it every morning. cheers!
Oct 16, 2008 | Linksys Wireless-G WRT54G Router
Internet connection
The only way to replace the network card is to replace the logic board in this unit, however if you are running 10.5, you can purchase an external USB to ethernet adapter at a local Apple retailer and you can hook the computer to the network through that adapter
Sep 26, 2008 | Apple iMac G4 Desktop
Wireless router
nee dto buy new pci wilress card be your best bet ok
Feb 11, 2008 | Computers & Internet
D link and Imac
If you don't put in the same wep key you won't be able to connect....take that S out..also not every device can connect to wpa ...use the same key if not able to connect reconfig the wireless settings change the key..,
Jan 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Cisco Lynksys Dual Band Wireless N Gigabit Router (745883589012) Logo
106 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
