Question about Citizen CT-S300 Printer
My CT-S300 beeps and stops while printing each receipt, even when I turn it off/on, take the paper out/put it back in...
The receipt stopped printing when ringing up items
the receipt can be turned on and off (toggled) by pressing the r on/off button on the far left. a small hyphen in the display will notify you whether it is in the on or off state.
Jan 14, 2014 | Casio PCR-T2000 Cash Register
Printer won't stop feeding paper Citizen CT-S651
if its printing ~@{}{@@ZXXCZ wierd things then its a driver problem and you need to reload it
Oct 11, 2013 | Citizen CT-S300 Printer
Ct-s300 printer is printing a blank spot down the receipt
Sounds like the heating element is covered or broken in that spot.
Feb 14, 2013 | Citizen CT-S300 Printer
Paper keeps feeding after the print of the page
First I would look carefully at the site you are printing from, some will not let you select pages to print.
somesites will have "printer friendly" that you should select otherwise you print ever page fir that website.
next see if you can view PDF before printing then select only the ones you want.
in conclusion the problem appears to be not with your printer but the web pages
Aug 08, 2012 | Citizen CT-S300 Printer
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
Plz solve my problem casio se-s300 problem is errror init/fc e004
If the register is new, this is normal, it just needs programming. Otherwise, it may have had a lock up.
Try this: Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down (may just be called FEED) - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL. Wait for print out. Turn key back to REG mode and try it.
If anyone needs more information, the Casio SE-S300 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Mar 10, 2011 | Casio Parts Cash Register PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
My canon mf8100 series prints once, then beeps and
set the paper size to A4 in ur computer and in ur printer
Aug 29, 2009 | Canon MF8180C Color Laser MFC Printer
Receipt won't print after paper change (and it IS thermal...)
not knowing what the model is I suspect the machine suffered a power surge or got a spill
Aug 26, 2009 | Casio Parts Cash Register PC Desktop
Error light will not stop blinking on my receipt printer; CT-S300. No manual so do not know any troubleshooting techniques. Help?
Hello
This is the direct link to the manual:
http://www.citizen-systems.com/support/downloads/CT-S300UM5_201.pdf
You will probably find what you need inside
Jun 27, 2009 | Office Equipment & Supplies
Citizen CT-S300 Printer Logo
115 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
