Question about Samsung Office Equipment & Supplies
Hi. I have a Samsung ML-2850 printer that is 8 months old. It was working great until there was a bad paper jam. After clearing the printed pages began to curl very bad - they become tubes. I've tried heavy paper. Is the problem fixable?
  • durf786
    durf786 Mar 31, 2011
    I was afraid of that. Thanks for the quick response!
  • durf786
    The solution explained why the problem started after fixing a paper jam, which is a lot of what I wanted to know.
  • 2,427 Answers
Well yes and no,
Firstly your problem has to do with the paper feed mech and gears, it may seem that while clearing out the paper you may have broken a gear on the wheels and now it isnt moving causing the paper to curl. You can take the printer apart and try to rebuild the gear mech but once you find the broken part, finding a replacement for it is a whole other matter..
try this ,,
remove the paper feed tray, Remove the back unit cover (what you open to remove stuck paper,
look at the wheels you will notice tiny gears that grip and pull the paper, rock eack wheel to make sure its sturdy if not, it runs along a bar, tighten the screws at the end on the bar.,
If that fails the gears need to be replaced and realigned which can be done at a samsung service center, Most often in these cases the candle cost more than the funeral so if you wish to repair it its up to you, But no matter how good its fixed it will still never print in alignment. So I'd suggest a new printer.
Posted on Mar 31, 2011
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
My Samsung ML2851ND jams on first page of two sided printing as it is being pulled back into the printer. The left side does not grab the paper as well as the right side. After the first page is cle
Dear
While duplex print some times this jam happen. Try on detach a leaver (black in color similar to comb) attached to back door of the printer.
Thanks.
Feb 04, 2015 | Samsung ML-2851ND Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
If the paper is jam in the printer
Without more specific information on where the jam is occurring in the printer difficult to provide a specific solution.
However, if you are having problems with paper jams you may find it helpful to work through the interactive troubleshooting guide found on this page under the Troubleshooting tab:
http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-laser-printer/ML-2510/XSS/index.idx?pagetype=prd_detail&tab=support
Under the FAQs tab on the same page you will find 3 guides for avoiding paper jams and 1 guide for clearing paper jams.
Trust this is helpful. Please vote. Thank you. :)
Dec 21, 2010 | Samsung ML-2510 Laser Printer
About 2 years ago, I purchased a Samsung laser printer, model number ML-2510. It performed very well until about a month ago, when I put in a new cartridge, number ML-201003/SEE which was different from...
/SEE is the cartridge for the European version of the printer, /XAA is the version for the U.S. I can't imagine why it doesn't work, but there's a reason for the European designation..
Jul 20, 2009 | Office Equipment & Supplies
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2010 Laser printer
LSU means "Laser Scanner Unit". That is the part that actually "prints" the image on the drum before it goes to the paper. If the toner (not ink) cartridge is in good condition, then you need an Authorized Service Center to replace the LSU assembly.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
652 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
