Question about Echo CS600P Gas Chainsaw 20 Inch
What yr was the cs670 echo chainsaw made - Echo CS600P Gas Chainsaw 20 Inch
  • 11,896 Answers
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ECHO chainsaw problem
You do not tell us which model Echo, that limits how much help we can provide. The head is probably in the oil tank.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/showthread.php?t=63219&highlight=Bar+stud+replacement
Post 6 in this thread is quite good. I have seen a post that required repair of the casting (with photos) to repair. I was not able to find it.
Look closely at the old one, once removed, See if it has some sealer applied
The IPL for your saw can be found here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed just type the model number into the search function.
If I can be of further help please reply below. HTH
Lou
Feb 08, 2010 | Echo Garden
How do i determine the age of an echo cs2900 chainsaw?
You should be able to find your answer here in the data base. http://www.echo-usa.com/faqs.asp
Jan 07, 2010 | Water Heaters
Wanted manual for echo 320 vl chainsaw
Ordinarily I would send you here for a download but your saw is not listed.
EchoUSA
Click “2. MANUALS, Catalogs, MSDS and Installation Instructions”
Then “Operator’s Manuals/ Parts Catalogs/ Safety Manuals/ ~more~”
Please try here:
http://www.echo-usa.com/faqs.asp?FAQPage=Quest
For all that follow you please include a request they add literature your saw to to the list. HTH
Lou
Nov 29, 2009 | Echo Garden
Just put a new cylinder and psiton on an Echo
Pin hole in fuel line can cause lean running condition. Also, be SURE the fuel is fresh and 89 octane or higher. Stale fuels can will give you pre-ignition and detonation issues that are nearly impossible to chase down. Ethanol blended or Oxygenated fuels are a NO-NO in high reving 2-strokes!
If fuel type and fuel line check good, go to carb inlet needle settings and then on to carb passagways.
Sep 26, 2009 | Garden
Please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Jul 18, 2009 | Echo Garden
Echo CS600P Gas Chainsaw 20 Inch Logo
152 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
