Question about Dishwashers
What does an arrow pointing right to a vertical line mean? i cant get the dishwasher to work
2 Suggested Answers
SOURCE: HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Posted on Feb 27, 2008
<(") what does <(") mean
on a remote it means left or right , left pointing arrow less than right pointing arrow more than . ( ) means do this first. " symbol for inches as in length.
Dec 25, 2014 | Cars & Trucks
I cannot make calls from Nokis N70 but am able to receive them. Text is OK. I have the symbol 2 followed by an arrow pointing to the right (with a 1 over it) and up against a vertical line. What does this...
you are used line 2 this situation is only for incoming (you try my solution type on display *#7370# &give your security code your mobile is restart on the mobile prosesing dont do anything) irfan_sai_2.jpg
Dec 14, 2010 | Nokia N70 Cellular Phone
How should i face the circulating pump on a vertical return pipe
Sounds like you are working with hot water heat or hydronic heat.
There should be a direction of flow arrow on the back of the pump
body. If it's a return pipe, then the arrow should point down the line to
the boiler. If the motor ends upside down, then remove the mounting
bolts on the motor and turn it right side up.
Hope this helps.
Nov 04, 2010 | Stanley Plumbing
Casio fx-9860G graphics calculater, vertical line segment
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
May 01, 2010 | Casio FX-9860G Graphic Calculator
Just want to know what the texting icon means. One has a check mark and one has an arrow pointing upward.
that usually means that you've done two different actions with the texts... the one with the check, means you only read it... the one with the arrow, means you replied or forwarded it
Mar 19, 2010 | Verizon Communications enV2 Cellular Phone
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
How do I print vertically?
  1. Type the text for the label.
  2. Press the "Function" key.
  3. Press the "Left" or the "Right" arrow key until STYLE is displayed.
  4. Press the "Return" key, which is the key with the broken arrow pointing left.
  5. Press the "Left" or the "Right" arrow key until VERTICAL is displayed.
  6. Press the "Return" key.
  7. Press the "Print" key.
Jun 29, 2009 | Brother P-Touch 1180 Label Printer
F2 Code
Fault F2 means the rotor is not rotating. If you say some of the vanes have broken off, they could have been jamming it. This should spin freely with minimal force when installed correctly. If you removed the rotor itself, you do ned to take care when installing it - there are 3 thin plastic legs around the magnet (the blue bit) these fit into 3 slots and you need to line them up very carefully. Once you have it right, it will just drop in. The rotor asembly as a whole is secured by turning the outside clockwise until the 3 points line up with the arrows.
Check the rotor is spinning freely, if not, remove it and check there is nothing lodged undrneath it of that it has been fitted incorrectly.
Re the broken vanes - you could try gluing them but I think it will break. The pump spins at 4200 RPM! You may need to but a new rotor.
Aug 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Feb 27, 2008 | Dishwashers
Dishwashers Logo
166 people viewed this question
Top Dishwashers Experts
Owen Barnes
