Question about Kitchen Ranges
When 12 v is connected there is a sharp spark and it starts to work. After 5 sec it stops and the red lite comes on indicating it is hot.
  • mrrog Mar 31, 2011
    I'm sorry, this is not a stove. It is a Xantrex DR2412 inverter. You did not have inverters in your list of things to choose from and I chose appliances.
    mrrog
    Brigadier General:
  • 3,513 Answers
What sounds here is that the temp sensor is giving faulty reading due to which the red light is coming fast and disconnecting the kitchen range .Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today are approx 1000-1100 ohm resistance at room temperature (70?F).
Thanks, please let us know if you need further clarification.
http://www.applianceaid.com/oven_temp_sensors_help.html
Posted on Mar 30, 2011
1998 Ford Explorer, 4.0 SOHC No Spark. Engine will crank but it won't start. Replaced the Crankshaft Sensor, Coil Pack, & Spark Plugs. Still no spark. What next?
You are at thhe right trail what controls spark is coil pack crank sensor sparkplugs and plug wire but the most important is power . I mean 12 volt connections and ground This includes checking fuses you need a simple volt meter doesnt have to expensive or fancy just to pick up 12 volts let start with fuses in the engine juction box (there not mark to what it belongs to) make sure none are open. especially fuse 19 and 24 , next go to the crank sensor make sure the tabs are snuggly on now to the coil pack there is a red and light green wire this comes from ignition and feeds 12 volts at the coil pack measure that voltage is it 12 volts if not correct it this is from ignition switch ( you can make a tool that feed 12 volt with a wire and a fuse in series and attatch it to battery and the primary wire this is known as hot wire) next go to the ECM wiggle the wires see if that get a connection going if not go back to the ICM here are the wire you are to measure the tan light green, this is from ECM and it is pulsed it measure 5vlts to 0 volts switched then measure the tan orange the same thing 5 volts to zero,then tan white again 5vlts to zero. any one of these 5 to zero fails you fix is the ecm
Aug 21, 2011 | 1998 Ford Explorer
Exhaust pipe glows red hot at a steady low rev and at start up instantly hot also little sparks come of it when revving the throttle.
The timing is set wrong OR You cannot let these 4strokes sit and idle.They all do it.They need to be ridden to get the air flowing over them to keep things cool.30 secs. idle at start and after a ride,idle for 10 secs. then shut it down.The sparks will probably be carbon build up inside the motor.You get it hot and they break away and come out through the pipe.All the 4strokes are a HP motor and will get hot if you sit and let it run.Hope this helps
Feb 16, 2011 | 2004 Yamaha WR 450 F
Doing about 55 on road . Temp low teens in Mn. Engine shut off. Pulled to roadside Car would'nt start. Engine turned over starter worked. Red Bat Indicator lite on All electric seemed to work Smell of...
The smell could be the cables getting hot from you trying to start it. It sounds like you lost spark so you'll have to test for this. Just get a spark tester from the local auto store for five bucks and plug it into one of your plug wires, clip the other end onto ground, and have someone turn the engine over while you look for spark to jump the gap. If you don't have spark, that will give us a starting point.
Jan 05, 2011 | Ford Crown Victoria Cars & Trucks
Sharp AR M-205 Blinking U 2
E prom error
Hold down the START button and retrieve the SUB-CODE,
EXample 04 or 11 or 12 or 40 ,
To clear:
Press #(button) interrupt(button) C(button) interrupt(button) within 5 secs.. then press one six (16) start (key)
Jul 10, 2010 | Sharp AR-M205 Copier
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
May 11, 2009 | Sharp LC-13AV1U Television
Oil Pressure or a lack there of
okay I dont think that one has anything to do with the other. I had this same prblem with my truck. The oil always had to be just past the full markor I got the oil light coming on. as far as the other prob youll need to start with fuel delevery and fire. check you timing, airfilter, spark plugs, pug wires basic troble shooting. then work your way up to the tpi, mass airflow sensors...ect if they apply good luck MrRodneyLong@Gmail.com
Jul 02, 2008 | 1992 Dodge Ram 250
Uniden cordless phone
To reset the indicator(Red light flashing on handset), press and hold the find handset key for 5 seconds or until the light flashing stops(10 sec).
Feb 04, 2008 | Uniden Cordless Phone
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
