Question about Gigabyte GA-M59SLI-S5 Motherboard
Will not boot just clicks - Gigabyte GA-M59SLI-S5 Motherboard
  • Gigabyte Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 30, 2011
Computer stuck in safe mode
When you boot into safe mode, click Start and type in the search box MSCONFIG. When you see MSCONFIG right click it and select run as administrator. Once MSCONFIG has opened, click the boot tab -> boot options and uncheck safe boot and finally click apply/ok.
Feb 27, 2015 | Computers & Internet
Tip
How to change boot screen in XP..???
1. First download and install Tuneup Utilities
2. Now click on Customize Windows -> Tuneup Styler
3. It'll open a new window. Click on "Boot Screen" link in left-side pane.
4. Now click on "Add -> Load Boot Screen From File..." option.
5. Select your boot screen file and click on "Install Boot Screen" button.
6. You can also create your own boot screens. To create new boot screen, click on "New Screen" button. It'll open a new window. Now click on "Search Local Drives" link and select the image.
You can also set the image alignment, borders, background color and progress bar position.
7. Once you finish, click on "Save boot screen" link and provide a name to your boot screen.
8. You can even see the preview of the boot screen by clicking on "Show large preview" link or by clicking on the image in Preview pane:
9. That's it, your new boot screen is ready. You can apply it by clicking on "Install Boot Screen" button.
on Jul 19, 2010 | Computers & Internet
Windows 8.1 is frozen in safe mode boot with network.
Go ahead and boot up in current safe mode. Log into Windows. Goto Control Panel/System and Security/Administrative Tools. In the list is a selection for SystemConfiguration. Dbl-Click it to activate. On the General Tab select "Normal Boot" then click the Apply button at the bottom. On the "Boot" tab, Remove the Check Mark from the "Safe Boot" box. Click the Apply button on the bottom and Click OK. Close everything and Re-Boot your computer. Should boot up to normal Windows.
Dec 30, 2013 | HP Computers & Internet
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Dual Boot
You may have overwritten your boot.ini file.
  • Click Start, click Control Panel, and then double-click System.
  • On the Advanced tab, under Startup and Recovery, click Settings.
  • Under System startup, in the Default operating system list, click the operating system that you want to start when you turn on or restart your computer.
  • Select the Display list of operating systems for check box, and then type the number of seconds for which you want the list displayed before the default operating system starts automatically.
    To manually edit the boot options file, click Edit. Microsoft strongly recommends that you do not modify the boot options file (Boot.ini), because doing so may render your computer unusable.
If both OS's are the same, you should be able to copy and paste the line for XP and simply change the drive letter to the location of the second OS.
Jul 10, 2012 | Computers & Internet
How to stop safe mode
goto Start > Run > type ' msconfig ' click on it ... a window will pop up 'Windows Need Your Permission To Continue' click Continue .. now at new window click Boot tab at top next to General .... at Boot tab look at the Boot Option uncheck Safe boot then click on Set as Default(optional) click Apply and hit Ok.
Dec 26, 2010 | Sony VAIO VGN-N320E Notebook
Safemode will not turn off when i select start normal
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode
Oct 19, 2010 | RCA VR702HF VCR
My laptop is at safe mode how do i remove it?
When the PC is on the desktop click on start then in XP click on RUN type msconfig - enter then click on BOOT.INI under Boot Options uncheck the box which says /Safe Boot, or in Vista or Win 7 type in msconfig click on BOOT under Boot Options uncheck Safe Boot.
THEN CLICK ON APPLY AND OK IN BOTH THE CASES TEH PC WILL RESTART .. This should fix it.
Aug 19, 2010 | Computers & Internet
How to change windows xp bootscreen?
1. Download and install TuneUp Utilities from the following link:
Download TuneUp Utilities
You can either purchase the full version or download 30 days trial version. After installation, run it from desktop or from Programs menu or by right-clicking on My computer icon and select "TuneUp Utilities"
2. Click on Customize Windows -> TuneUp Styler
9. Your new boot screen is ready. You can apply it by clicking on "Install Boot Screen" button.
May 26, 2010 | Microsoft Computers & Internet
Change xp bootscreen resolution
You can not change the bootscreen resolution. The bootscreen has to be 640x480 px and 16 colors. Nothing else will work.
There is a great video about how to change your boot and logon screen in Windows XP. Look here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 19, 2009 | Microsoft Windows XP Professional
Gigabyte GA-M59SLI-S5 Motherboard Logo
74 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
