Question about Dryers
What amperage should my dryer be drawing. My amp probe readings are around 27 amps and some where in the drying cycle (not the begining) it will blow a 30 amp fuse. ?? Is my problem in the heating element or possibly the motor?
  • 1,543 Answers
You can check elements and motor seperately. Most dryers use a 4500 watt element, devide by 240 volts = 18.75 amps. Motor generally is 3 amps or so, for a total of about 22 amps. A circuit pulling close to the rated max amps will eventually blow. Make sure to test all electrical connections for a good solid connection. (at the dryer to cord, wires to terminals inside dryer recepticle, and at the fuse/ circuit breaker panel.)
Posted on Mar 30, 2011
8756 machine freezing up and icecream to thick what can it do to change problem
You can adjust the viscosity.
In soft serve and frozen yogurt machines, the logic board X36641SER2Refurbished Gen 2 Logic Board This item is sold with exchange...measures the viscosity of the product by monitoring the amp draw of the beater motor. When the machine reaches the set point, it cycles off and the product is ready. In auto mode, you can only adjust product viscosity, temperature in the freezing cylinder is not monitored.
The power board measures the amp draw. L1 power supplied to the beater motor goes through the power board on the beater terminals. Single phase and three phase units use the same Softech control, so the power board allows for different amp draw ranges. A jumper on the power board determines the amp draw range. Place the jumper on the pin that corresponds to the amp draw of the beater motor when the product is at the desired viscosity.
Setting Viscosity Adjustment
1. Place an amp probe on one of the L1 leads on the beater terminal on the power board.
2. Turn the viscosity adjustment screw to the "MAX" position.
3. With the freezer properly primed, press "AUTO".
4. During the freezing process, draw samples and inspect the product appearance. When the desired product viscosity and appearance is achieved, note the beater amperage.
5. Press "AUTO" to cancel the refrigeration cycle.
6. Using the chart, set what range the beater motor amperage falls into and place the jumper on the corresponding pin.
Viscosity Control Chart
2.4 pin - 1.2 amp to 2.4 amp
5.0 pin - 2.5 amp to 5.0 amp
8.0 pin - 5.7 amp to 11.2 amp
7. Press "AUTO". When amperage reaches the noted draw, turn the viscosity adjustment screw SLOWLY until the unit cycles off.
8. Draw several samples to verify the product and amperage when the machine cycles off remain consistent.
Adjusting Viscosity
To increase viscosity, or make the product harder, turn the dial clockwise towards maximum. Important: The dial only turns a limited amount if it stops turning do not force it.
To decrease the viscosity, or make the product softer, turn the dial counter-clockwise towards minimum. The dial only turns a limited amount do not force it once it stops.
We recommend you only turn the dial about 1 hour on the clock, at a time. Once you have made your adjustment, pull the handle to start a new cycle, when the machine cycles off check the product again.
adjusting viscosity on taylor frozen yogurt machine-5jpt2eusobswb402obrm5sjf-2-0.png
Jun 06, 2017 | Ice Cream Makers
My maytag electric dryer start switch went out. I replaced it and it burned out again.
Good day,
It's possible you just got a bad part. If it's under 90 days you should be able to return it.
If that corrects the problem, then the only thing causing premature failures would be the motor drawing too much current. However, other issues usually show up such as the machine shutting down before a complete cycle is run, or you have excessive noise indicating bad bearings causing the drum to drag and overloading the motor.
P.S. The only way to determine if the motor is drawing excessive current is with an amp probe. If you don't have one, try to borrow since they are very pricey. It's a device that clamps around one of the motor leads and gives you a reading, while the machine is running.
If need be, post back on more detailed use of this tool. Electricians carry them as well.
Aug 24, 2010 | Dryers
The dryer isn't getting hot. I know there's a
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Hotpoint ultima cd80 condenser dryer has stopped heating can it be repaired/reset or is it a new unit and how much? Cheers
Hi
• Empty dryer.
Thanks
Rylee
Nov 10, 2009 | Hotpoint Dryers
Heating element drawing lots of power, big bill power
Well a dryer heating element does draw quite a bit of amps(that is why it is 220) but it cycles on and off & it is not an appliance that is used everyday. The first think I would do is read the electric meter and verify that it was not misread before condeming the dryer. If the electric meter reads are correct then it is possible it could be the dryer heating element shorting. How much do you actually use the dryer? Is the heating in your house electric and have you been using it? You could also have your electric company test the meter. Look at your usage of electricity for last year at the same time(it will be on the bill) and see what the number was.
Oct 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
My dryer won't start, but I think the cycle button won't engage.
Hi
Thanks for using FixYa. The issue might have happened due to a blown fuse or burnt wiring/components on the control board. You'll need to check and replace the fuse and replace it.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Whirlpool LER4634J Electric Dryer
Dryer continues to run but heat fuse blows when turned on.
You would need to check the amp draw to determine if it is the dryer or your house circuit. A dryer typically draws a steady 24 amps when it is heating.
Apr 07, 2009 | Whirlpool GEW9250 Electric Dryer
Hi I have a Roper electric dryer since 2000 never had a problem also had an electric dryer for 6 year before that never had a problem with breaker going off now its been happening frequently, all the...
You will neeed an AMP meter.
Take the face cover off the breaker box.
Very carefully, without touching any wires and frying yourself check the amperage on the wires (one at a time) coming off the breaker to the dryer. (While its running with a load of wet clothes)
If the amp draw is very close to the amp rating of the breaker (IE 30 AMP breaker dryer drawing 28.5 AMPs) then you likely have an issue with the dryer and s the amp draw fluctiates a little it pops the breaker.
Several things can cause this. Motor windings going bad, elements going bad, dryer in need of a thourough cleaning etc.
There could also be a short to ground with one component/switch that is only energised during certain cyles. Keep note of when it trips the breaker. If you notice a pattern, that will help determine the problem.
If none of this applies, and the breaker is just poping randomly without having an amp draw higher than its rating, then you have a bad breaker.
If you have no amp meter. You could try replacing the breaker.(With the same rating, DO NOT go higher unless you want a really big bonfire.)
Most breakers are less than 20 bucks.
Thats an easy job, and if will help you isolate the problem by knowing if it's the dryer or breaker.
Otherwise you must either have a good Volt/OHM/Amp meter to trace down the problem.
Jan 01, 2009 | Roper REX4634KQ Electric Dryer
New igniter, still won't work
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Nov 06, 2008 | Hotpoint RGB745 Gas Kitchen Range
Dryers Logo
71 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
