Question about Maytag Neptune MCE8000AY Electric Dryer
The top does not shake
My dryer works fine but the top does not shake
I had the same problem. I had to purchase a new shaker unit..very easy to do yourself. Now it works fine again. You can run a diagonsic yourself if you dare to check it. Hidden behind the control panel is instructions on how to do it. I learned this when the repair man came out when still under warranty to fix a problem. He was very upset that I wouldn't let him put the paper back. Oh well, I own it, not him.
Posted on Aug 27, 2008
Whirlpool dryer leq8611lw0 shakes violently and makes loud noise
Something must be inside the blower wheel. I cannot imagine why it would shake like that. This dryer has 4 wheels instead of 2 so it oughta be stable. The only thing to do is get inside the machine and see what is causing it. The dryer with a filter inside is also sometimes known as a series 90 dryer. Look for some series 90 dryer videos on youtube. Like this crappy one I made:
Apr 22, 2014 | Dryers
One of the ties of my scrub top got stuck in the lint catcher (the catcher was out of the dryer doing use). I had to pull it out and it broke off. Now the dryer makes this louder noise and shakes a...
you need to remove the back of the machine, and remove the vent cover inside the back,, you'll see a fan blade,, that cord probably got turned around the fan,, Just remove it and you should be fine, Unless it broke off some of the blades, which will cause it to vibrate and not flow the air as good
Jul 15, 2011 | Dryers
I have a frigidaire dryer. The motor humms but the drum does not turn. The belt is not off the drum.
a humming (shaking) motor means the coils have lost there magnetic feild (replace the motor) and it will work fine
please remember to rank this post
thanks
Jun 21, 2010 | Dryers
Front loader washer shakes house
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 06, 2010 | Washing Machines
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Washer and dryer where installed today. Stackable 3000
hi your sheets need to be even in the wash or it will fined a wobel out of balence cheers peter
Apr 05, 2009 | Maytag LSE7806A Top Load Stacked...
Your answer to my whirlpool duet dryer problem
You have got a bad connection somewhere, it could be in the timer unit,or the door switch, take off the top and shake the wires with a rubber glove on, the machine would have to be on to do this,be careful,you can by pass the switch by joining the two wires If there is just two.If only I had it in my work shop, but Ireland is too far away good luck.top of the morning to you as all us paddys say!
Nov 30, 2008 | Dryers
Maytag Neptune MCE8000AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
