Question about Dmm Case D,dc,dh Tractor Air Stack
Have a 1950 case dc need to know how to tell if tramission fluid level is full or not
Can you tell me how to chech tramission fuild where it is located
I know they made some changes in 95, but I am not sure about the tranny dipstick. The 94 had the dipstick on the passenger side of the engine, towards the rear, the oil stick sits right in front of it. You check the fluid hot, while running, in park. and you fill it right there too, with along neck funnel. Now, if you don't have the dipstick, then they changed that year, there are 2 plugs on the right side of the tranny, crawl under there and find one up, one down, the bottom one is level and the top is fill. Pull the bottom one out, while cold, not running. if oil seeps out, it is full, if no oil seeps out, pull the top plug and fill with the right fluid till it seeps out the bottom hole, I use 90 weight gear oil top on the tranny fluid bottle and squeeze right in there, then plug them back up. Hope this helps.
Jun 12, 2011 | 1995 Honda Passport
My car says tramission fault
Could be fluid, pressure, electrical or mechanical.
When fluid low and you brake hard or accelerate hard, fluid runs away from oil pick up and air enters system. This allows clutches to slip and weak band apply pressures.
In any case you need a shop or dealer to scan the transmission module to pull the codes.
Many case this is water in the electrical connections to the transmission under the car.
Pull up rear floor carpet and trunk covering...check for water. Common problem with Jaguar.
Jan 15, 2011 | 2003 Jaguar S-Type
TRAMISSION OIL CHECK
look on the gear box caseing there is a big alan screw head thats the gear box oil filler,, the tranamission filler is on the dif the same kind of alan screw,, dont over fill the gear box or the dif oil
Mar 08, 2010 | 2002 BMW K 1200 LT
My chk at light came on yesterday,my son just
You can't really know unless you get the associated code. Some autoparts places will do this for free. Try Autozone or a local alternitive. Then they will tell you what it means or you can research on line.
Unfortunetly most chk ligt issues won't just go away you have to have them deleted.
Mar 04, 2010 | 2005 Nissan Altima
2002 galant transmission
OIY VAY!!! WACKY QUESTIONS,BUT, HERE I GO AGAIN! YOU KNOW WHERE THE DIPSTICK(NO NOT YOU,UH WELL..)FOR THE TRAMISSION FLUID LEVEL CHECK IS?(HOPE SO)WELL THATS WHERE YOU ADD FLUID!!! DAMN!! MY 5YR.OLD NEPHEW KNOWS THAT!!!
Dec 17, 2009 | 2003 Mitsubishi Galant
How do I check the fluid level in my 1950 Windsor,
put it in neutral with hand brake applied firmly!
run engine at normal temp!
pull out the trans dip stick from its tube !
check oil for burning smell or discolouration !
then wipe clean & reinsert all the way till it seats & remove at once!
check th oil against the marks on the stick!
if its low, top it up but never overfill as it can create too much internal pressure & blowout the oil seals! ok
Jul 18, 2009 | 2007 Chrysler 300 AWD Sedan
Lubricant level check, how? Rear differential case
There should be a drain plug on the bottome and an fill plug on the top. Remove the fill plug. Yeah I know this shounds weird.
You can put your finger in the hole and feel the fluid on the tip of finger If not then full up until you feel the fluid on he finger. Your owners manual also can tell the amount of fluid needed and what type. You may have to add some additive to keep the bearings and gears from damaging .
Apr 11, 2009 | 1992 Ford F250
Transmission fluid level?
There is a 11mm plug on the passenger side of the trans near the axle shaft. Remove that with the car level, trans hot, and engine idling. Fluid should just come out of there when its full.
Sep 06, 2008 | 2005 Chevrolet Malibu Maxx
Add tramission fluid to prevent slipping gear changes
no check fluid level when engine at idle by looking at transmition dipstick, add fluid only if needed.
Jul 17, 2008 | 1995 Toyota Camry
Dmm Case D,dc,dh Tractor Air Stack Logo
51 people viewed this question
Top Dmm Garden Experts
Wayne McNeil
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Dmm Garden Expert? Answer questions, earn points and help others
