Question about Texas Instruments TI-36 X Solar Calculator
I'm trying to figure out my nCr button. If I type in 7 as my n, and 4 as my r I just get zero!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press 7 x<>y 4 3rd [nCr]
Posted on Sep 01, 2013
A Committee has 19 members, of which 10 are Democrats and 9 are Republicans. A subcommittee is going to be formed with 3 Democrats and 3 Republicans. How many possible subcommittees can be formed?
How many ways can you select 3 members out of 9 republicans: nCr (9,3)
How many ways can you select 3 members out of 10 democrats: nCr(10,3)
For each single choice of 3 reps you have 1*nCr(10,3) possible subcommittees.
Hence the total number of possible suncommittes is nCr(9,3)*nCr(10,3)
Explictitly
# of possible subcommittees is [9!/(3!*6!)]*[10!/(3!*7!)] or 10080
To calculate you can use the explict formula above or use the nCr function of your calculator
To access the nCr( function press [2nd][5] (MATH) [7:Probability][3:nCr]
You can also just type the name of the command respecting the case ( C must be upper case)
Jan 31, 2010 | Texas Instruments TI-89 Calculator
How to use binomial in calculator
The binomial probability distribution is defined as
P(r;p;n) =(nCr)(p^r)*(1-p)^(n-r), where n is the number of trials, p the probability of success, and r the expected result.
Let n=20, r=7, p=0.15 ( I do not know wether this exemple has any meaning in the context of your problem, but you have to enter values that mean something to you.) I am only showing you the key strokes
To enter 20C7 you press 20 [SHIFT][nCr]7 ;
To enter 0.15 to the power 7 you type 0.15[X to ] 7 the key is between
[x²] and [log]
To enter (1-0.15) to power 20-7, you type 0.85 [X to] 13
With [*] standing for multiplication key , and [X to] the raise to power key, the exemple above can be entered as
( 20 [SHIFT][nCr] 7) [*] ( 0.15 [X to] 7 ) [*] ( 0.85 [X to] 13 ) [=]
Here is a screen capture to show you what it looks like. However on this calculator the combination 20 [SHIFT][nCr] 7 is represented as nCr(20,7).
Dec 06, 2009 | Casio FX-115ES Scientific Calculator
Binomial function
Let n=20, r=7, p=0.15 ( I do not know wether this exemple has any meaning in the context of your problem, but you have to enter values that mean something to you. I am only showing you the key strokes
[x²] and [log]
Hope it helps
Nov 12, 2009 | Casio FX-115ES Scientific Calculator
Binomial function in calculator fx-911ES
[x²] and [log]
Hope it helps
Nov 03, 2009 | Casio FX-115ES Scientific Calculator
I need to change an NCR 7875 - 2000 from lbs to kg Regards Peterm
Firstly you will need NCR Scan Tags. You can download from
http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
You will have to print out the Scan Tags which start at page 281 and you will also need the correct weights; 0kg, 2.5kg, 5kg and 10kg.
Then follow these steps and be sure to scan tags in correct order:
1. Reset
2. Default
3. Program mode
4. Hex 3
5. Hex 0
6. Hex 1
7. Push the calibrate button under weighing tray
8. Place the correct weights in order. It will ask for the weights in order.
9. Calibration complete
Jun 05, 2009 | NCR 7875
Wheelwriter 6 will not print dark on 4 page NCR paper.
First try a new IBM brand ribbon part # ends in 999. NCR paper can be difficult try the code "Q" this should increase thr impression.
DickyO
Mar 16, 2009 | IBM Office Equipment & Supplies
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
I'am looking for Free NCR Media Software.
I contacted NRC and this is the answer they gave me.
Please access the templates from the website listed below. If you need additional assistance, please contact our customer service center at 800-279-0203, ext 1 for product support. thank you
http://www.ncr.com/products/supplies/sup_rop_printer_labels_inst_product.htm NCR
Apr 11, 2008 | Office Equipment & Supplies
NEED ACTIVATE READ OF CODE 128 IN NCR 7872 SCANNER
Reset
Defaults
Prog.mode
Hex 1
Hex 7
Hex 1
Hex 1
Hex 0
Save & Reset
Aug 14, 2006 | NCR RealScan 7872 (787220509090) Fixed...
Texas Instruments TI-36 X Solar Calculator Logo
29 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
