Question about Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum
Home-tek penguin hand held steam clener HT895 light going on as ready to use but no water being released.
SOURCE: No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Posted on Nov 08, 2007
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
SOURCE: does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
Posted on May 20, 2009
heatman101
  • 43501 Answers
SOURCE: shark steam mop power light goes on, basin feels
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 30, 2010
Can the nozzle get blocked and affect the pressure of the steam
Yes particularly if you use hard water (high in mineral content)
Aug 09, 2014 | Euro-Pro Steam Penguin Hard Surface Steam...
Hand held cleaner
The pump is probably faulty and needs replaced
Mar 03, 2014 | Hoover F5835900 Upright Steam Vacuum
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
I have the steamtek steam cleaner for 5 months and it will no longer steam!
We had the same problem. I took the unit completely apart and it seems it doesn't like our hard water. I took off the head (one screw at the base and it slips off) and I put a tooth pick into the steamer hole to clean any clogs. Then I ran a cup of CLR through it with equal parts water and it runs fine but not as good as it did new. We are going to only run distilled water through it from now on. Hope this helps!
May 19, 2010 | Vacuums
Have water at the hand held but none out the bottom
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhklui
Nov 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Leakage from eureka deep steam carpet claeaner
You will just have to take it apart to see if a hose is loose, came off, or is cracked.
Jun 14, 2008 | Eureka 2576A Steam Vacuum
No steam release
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum Logo
992 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
