Question about Sony Vaio PCG FR415S Laptop AC Adapter 19.5V-6.15A 120W (AC48VPND2MYQT)
My laptop charger, after about 1 and a half years of use, has begun to make a strange, high pitched noise and refuses to charge my laptop.
  • 66 Answers
In most modern laptop chargers, this high pitched sound it emitted when a "safety switch" has been activated in the charger. It is possible that there may have been damage to one of the components in the charger. The only solution is to replace the charger.
Posted on Mar 30, 2011
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Sony Laptop Power Problem
Without knowing how old your laptop is, I suspect that the problem is the charger, if its over 1-2 years old, you may have to replace the charger, the problem may be that the laptop is draining too much power for the worn out charger to provide and it switches to battery power instead.
When the laptop is turned off there is less of a drain on the charger and it still has enought juice in it to charge the battery, but not run the laptop at the same time.
Jun 11, 2012 | Sony Computers & Internet
Buzzing/whining noise while on charge.
This sounds like a cooling fan issue, inspect that....Clean the unit while you're in there, heat kills.
Feb 29, 2012 | ASUS Eee PC S101 (EPCS101B-BLK043X) PC...
My charger keeps beeping a very faint, high pitched beep, its a T135S1305 Satellite and it isnt charging my computer, this happend once before and started charging again the next day.
i had the same experience like you do, the best solution is buy a new charger before it break your laptop...
my laptop is already broken because i didn't change the charger
please rate
Feb 27, 2011 | Toshiba Satellite T135S1305 (PST3AU00H008)...
My Acer Aspire 5100 laptop makes a loud high pitched consistent noise when I try to turn it on. then the noise stops, then a black screen comes up with writing, but when i hit resume, the computer restarts...
The problem might be the power supply charger that plugs into the laptop, unplug the charger and run the laptop on battery power, is the high pitch sound there when you power up? if this solves the problem, it is the power supply charger that is the cause.
Jan 08, 2011 | Acer Aspire 5100 Notebook
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
High pitch noise
what you are hearing is the mechanical vibrating of coils & or transformers in the tv. 1st and easyest is to hot glue the parts that is making the noise down. if that does not work, removing & reinstalling the part is next. the last is replacement. the most likely parts causing is the 1. horizontal linearity coil, 2. the run or switch mode transformer, or 3. the flyback transformer. good luck.
Jan 09, 2007 | Zenith C27F33 27" TV
Sony Vaio PCG FR415S Laptop AC Adapter 19.5V-6.15A 120W (AC48VPND2MYQT) Logo
89 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
