Question about Panasonic NNSN797S Microwave Oven
Have to slam door to get oven to operate - Panasonic NNSN797S Microwave Oven
  • 3 Answers
Try a) Lubricate the latches. I sprayed wd-40, you probably can use vegetable oil. Both sides, latch and receptor. Just doing this may fix your problem. (I have to admit I did part b first before trying this so I am not sure, but after doing this, it made my part b fix work even better)
b) Failing this, I found opening it up (t-20 torx screw driver) and tying a wire in the top hole, through the bottom latch body and fastening to a bottom hole of the microwave frame to force the mechanism to stay in place. You want to pull it towards the oven cavity. This will keep it from bending out of alignment. I found that it is only the bottom latch that has to catch for the microwave to sense the door is closed.
have to slam door to get oven to operate - slam-door-get-oven-operate-41qvhcwfyh1nhfrs4aojrhur-1-0.jpg
Posted on Jan 17, 2015
  • Helen Chun
    Helen Chun Jan 17, 2015
    Forgot to mention you probably need to unscrew the assembly and bend the metal back to alignment first. It will be bent away from the oven center if it is not latching.
    Brigadier General:
  • 8,909 Answers
I would check the door switch settings before the door damages the switches. Removing the cover may be dangerous!
The door catches can be adjusted when the cover is removed and disconnected from any power.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Posted on Mar 30, 2011
Microwave will not operate unless I slam the door shut then program to cook.
of course it is , most likely needs a new door switch .
Oct 21, 2015 | Microwave Ovens
I have to slam the door 5 times to get it to turn on
Have you tried leaving it after GENTLY closing the door once? Many have a timer so that the fan can remove condensation from the inside. If that doesn't work, you need to take it to the nearest Panasonic service centre to have the door microswitch adjusted or replaced. There are no self serviceable options with microwave ovens due to the disastrous damage operating one without the outer case can cause. The use special screws only the tech carry.
At least you have a good make, so worth having it fixed. I used Panasonic ovens in a restaurant setting.
Sep 19, 2015 | Panasonic Genius Prestige Inverter...
Microwave power off, but will flicker when door shuts
Please inspect the plastic latches that should actuate the door switches. Sounds like you may have broken one when slamming the door too hard
Mar 20, 2014 | Samsung SMH9151 Microwave Oven
The 20 amp power fuse blows every time i start the mircowave oven?
The oven probably has a bad interlock monitor switch, one of several switches in a microwave that are operated by the door latches. The switch is wired so the fuse will blow if you try to run the oven with the door open, and it isn't operating properly when you close the door. As soon as the oven kicks on the power to the magnetron tube, the microwave source, the fuse blows. The switch may have been damaged if the door was slammed, or it's just a mechanical failure. It's not an expensive part, but any microwave repair involving the door should be done by a professional because of safety concerns, so you will have some labor cost to add in. It shouldn't cost as much as a new oven to make this repair, though, so it's probably worth fixing.
Jan 13, 2011 | Hotpoint Microwave Ovens
Door got slammed and now it does nothing
There are two or three switches operated by the door latches in a microwave oven. When the door is slammed, they can be damaged or knocked out of adjustment. If the control board thinks the door is open, it won't allow the oven to operate. It's best to let a professional check the oven and adjust or replace the affected parts. Microwaves are hazardous devices, with lethal voltages exposed when the cover is off. Also, repairs involving door repairs can cause microwave leakage if they aren't done properly. But once the switches are operating properly your oven should be fine.
Jan 08, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have to slam door to operate
Check for loose wiring inside your system. You are going to have to pull it out and make sure that no wires are loose. You are having a grounding issue or a loose wire that is not making contact with the door switch.
Jan 01, 2010 | GE JEB1095 Convection/Microwave Oven
Micro blow circuit
You have a faulty interlock switch. This is one of two or three switches in every microwave that are operated by the door. The interlock switch is wired to blow the fuse if you try to run the oven with the door open. The switch may have gotten knocked out of adjustment (say by slamming the oven door) or its contacts stuck closed. If there are no other problems with the oven, a new switch should clear this up.
Mar 24, 2009 | LG LMV1630 Convection/Microwave Oven
Door slammed and no microwave is dead
yep you got it in one, I must have advised about 10 people today about this. when the door is slammed the door protection circuit does not operate correctly and then takes out the mains fuse inside the unit. renove the case and locate the fuse, normally where the cable enters the unit. as long as the fuse is the correct amperage, lenght and diameter you have no problems. do not test the unit with the cover off and be careful as the capacitors can hold a lethal charge
Feb 19, 2009 | LG LMV2053 Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Panasonic NNSN797S Microwave Oven Logo
793 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
