I have a Toshiba Satellite Pro Celeron running XP pro. When I updated with service pack 2 and 3 the screen boundaries shifted about an inch to the left leaving a dark bar down the RH side of the screen, and the desktop is now displaced to the left so that an inch of it is off the screen although it can be dragged back central again, when the RH side disappears into the dark area. Is this a known problem and what might the fix be please? Many thanks. Roger Middleton.
  • RogerM9 Aug 05, 2008
    Thanks autosoundins. Eventually went on to the Toshiba Europe website. Coudn't find my model number (it's old!) but joining the owners club enabled me to input the serial number which identified the model. From there I downloaded the display drivers which resolved the problem.
    Meant to hit the "helpful" button to grade your reply. Sorry if I appear to have damned you with faint praise - your response was very helpful.
    Champion:
  • 232 Answers
CALL TOSHIBA TO MAKE SURE U DON'T NEED A SERVICE PACK THAT WAS DEVELOPED FOR THAT UNIT
Posted on Aug 04, 2008
TOSHIBA SATELLITE PRO L300: PSLBDG : PROBLEMS: 1) Restarts automatically when i plug in the power cord. However works fine in Battery. 2) Shuts down when i try to install graphics driver after a clean...
Replace the AC Adapter, (ebay from £10.00).
Did it come with XP on it? Mine came with Vista and there are conflicts with XP and graphic adapters. There is no XP driver for the ATI adapter in mine.
Go online to Toshiba and download all of the updated drivers that you require. A user friendly system.
Dec 22, 2010 | Toshiba Satellite Pro L300 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          NO SOUND ON MY TOSHIBA Satellite U405
          It is probably a driver issue. First check the device manager, from the Control Panel. A red triangle with an X or a yellow triangle with an exclamation point indicate that the issue is with the driver.
          http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download will let you search for your model and download the XP sound driver.
          The specific driver may be: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2043975&rpn=PSU41U&modelFilter=&selCategory=3&selFamily=1073768667# (using the Satellite Pro U400-S1001V above)
          I hope this helps.
          Jul 16, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
          Ive updated my windows vista 32bit with service pack 2
          Hi, This is a known issue as part of the ongoing updates from Microsoft. The general recommendation from Microsoft is for you to install the System Update Readiness Tool.
          You can find the detailed Microsoft instructions here: http://support.microsoft.com/kb/947821
          If the basci recommended steps don't solve your issue, then please download & run this.
          Best of luck, Ed
          Nov 25, 2009 | Toshiba Satellite Pro P300 Notebook
          Re-installed XP Pro + SP2 + SP3 - but have black screen
          reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
          Sep 23, 2009 | Dell Latitude D600 Notebook
          Satellite pro sp2100 ps210e-606-p4-4d intel celeron. My recovery cds have got corrupted and I am looking for the LAN card drivers> can you help?
          you can get lan card driver on webside. serch in this way "www. free xp supported vistasupported/lan card driver of satelite pro sp2100...........intel celeron" ithank u can get it on "www.driverstock .com"(nepal}
          Jul 11, 2009 | Toshiba Satellite Pro A210-EZ2202X...
          Problem loading XP Serve Pack 2 in Gigabyte 8I845GVM-RZ
          I know this may sound mundane, but did you load the correct set of windows drivers for the Intel 845 chipset? I mistakenly loaded the Home drivers onto a unit I tried to install Pro on and I got all sorts of errors.
          Mar 26, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
          Continuous loop and cannot charge battery
          Windows service pack 2 is a huge update and takes a long time to complete, I will suggest walking away from your computer and having lunch, go to sleep, watch a movie, etc... while the update finishes. If you have already done this with the same result? I would look for a Windows XP SP2 disk (XP with service pack 2 integrated) and try that. Otherwise Microsoft sent out many disks containing the SP2 update itself on a disk, and you could try the SP2 update from one of those (if you can find one) after your clean install.
          Good luck.
          Feb 24, 2008 | Toshiba Satellite Pro M15-S405 Notebook
          Computers & Internet Logo
          David Payne
          David Payne
