Question about Lands Phones
I PUT IN A PHONE POINT IN BEDROOM FROM MAIN TELEPHONE POINT FOR THE COMPUTER USING NUMBERS 2 , 3, 5, WE HAVE BROADBAND EVERYTHING WORKS BUT HAVE READ SOME INFORMATION SAYING YOU DONT NEED TO WIRE NUMBER THREE AS THIS WILL SLOW MY COMPUTER DOWN IS THIS CORRECT
  • 11,896 Answers
Most routers have 5 ports plus the one port for modem to router. Numbers 1-5 all use the same channel and frequency. All numbered ports are exactly the same.
Posted on Mar 30, 2011
How do i get volume on my binatone 3325 handset
Press C/8 to unmute the microphone.
complete installations
Plug the power adapter
& line cord
into the base station.
Plug the power adapter into a 230Vac, 50Hz
mains socket, the other end of the line cord
into your telephone line socket.
Warning: Always use the line cord provided in the box.
Other line cords may not be compatible and may not work.
Warning: Only use the power adapter supplied.
Others will result in non-compliance with the safety
specification EN60950, and will invalidate any approval
given with this apparatus.
Warning: The Base unit needs mains power for
normal operation, not just for charging the handset batteries.
Installing and charging the batteries
Slide open the battery compartment cover.
Place the 2 batteries with the correct polarity,
as shown.
Slide the battery compartment cover back.
Put the handset on the base and charge for
15 hours before first time use. The handset
beeps when charging starts.
Warning: Only use the AAA size NiMH rechargeable
batteries.
If you have a Broadband Line
If you connect your telephone to a line with a broadband connection, you will need to
insert a micro-filter between the telephone and the telephone line, otherwise you may
get interference between the telephone and the broadband, which could cause
problems.
In a home with broadband, every telephone must have a micro-filter connected, not just the one at the telephone point that your modem is connected to.
If you need more broadband micro-filters, contact your broadband provider.
Connection and Conditions for use:
You can connect your phone to a direct exchange line (DEL) on a local
exchange with its own phone number; to an extension socket
connected to a DEL; or to an extension on an approved compatible
PBX. Do not connect as an extension to a payphone.
The ringer equivalence number (REN) of all equipment (phones, fax
machines, modems, etc.) connected to an exchange line must not add
up to more than 4, otherwise one or more of them may not ring and/or
answer calls correctly. This phone has a REN of 1, and most other
telephones have a REN of 1 unless marked otherwise.
Handset - Base Connection
1) When purchased, all handsets are already registered to the base unit
and should link to it when they are all powered up.
2) To use your cordless handset and base unit together, you must be
able to establish a radio link between them. The signal between the
handset and the base is in accordance with the normal standards for
a DECT phone: Maximum range up to 300 metres outdoors or 50
metres indoors. Be aware that:
> Any large metal object, such as a refrigerator, mirror or filing cabinet,
between the handset and the base unit may block the radio signal.
> Other solid structures, like walls, may reduce the signal strength.
> Other electrical equipment may cause interference and/or affect the range.
3) Do not place close to another telephone, a TV or audio equipment - it
may cause interference.
4) Out of Range warning. If you hear a warning tone during a call,
and/or the sound in the earpiece becomes faint or distorted, you may be
going out of range of the base unit, so move nearer to the base unit
within 20 seconds, otherwise the call may be cut off.
Jul 20, 2014 | Lands Phones
Tip
Laptop battery systems allow you to contact a user that may be walking...
laptop battery systems allow you to contact a user that may be walking around.dell latitude c600 battery Each system has a base unit which enables you to page the handset of a user, so long as they are in range. You can then speak to the user through the intercom facility. Some systems allow you to use another handset as the intercom instead of the base station.
http://profiles.yahoo.com/blog/
How you ask? With Internet phone service, or more specifically, broadband phone.dell kd476 battery Don’t be confused by the name. A common misconception is that you’ll have to use, or have your computer running to use broadband phone service. Not true my friend! Your computer can be completely shut down, and you don’t need it at all to use your telephone with broadband phone service. No more headphones, no more typing in phone numbers, just use any touch tone telephone to make and receive phone calls the same way you always have.
How is this possible? You may be shocked by this but, you’re essentially cutting out the middle man to transfer your incoming and outbound phone calls with a tiny black box that does the same job your traditional phone company has always charged you for. It’s called a broadband phone adapter. The broadband phone adapter uses your Internet connection, (not your computer) to send your calls out to the same grid your traditional phone company uses to transfer phone calls! By cutting out the middle man, (your phone company) you’re also cutting out a huge chunk of your phone bill.
There is growing consensus that laptop battery antennas may be harmful to humans due to the huge volume of electromagnetic waves that get concentrated around it during the receipt and placing of calls. This danger is even further aggravated by cellular manufacturers who place the internal antennas close to the earpiece.
on Mar 31, 2010 | Computers & Internet
Caller display doesn't work
From the BT website...
"If you are using your phone on a broadband line make sure you fit an ADSL microfilter between the telephone line cord and the telephone socket."
I'm guessing you have one on the landline, probably next to the router but not the handset base :-)
Why is my Caller Display not working Help BT com Help
Apr 23, 2014 | Lands Phones
Telephone stopped working broadband works
Try ringing your supplier,more than likely a fault in the main box in the street,you can ring for free from a friends landline and they can check the fault,they will ask for your phone number and run a check on it
Feb 02, 2012 | Motorola Lands Phones
I assembled it without a manual because i cant find one, and i cant seem to work it everything looks good but with the lense i cant quite seem to work it, ...
Put the eyepiece with the largest number written on it into the focuser. DO NOT use the 2x barlow if you have one.
Go outside during the day time and practice focusing on a distant object using the eyepiece mentioned above.
Line up the small finder scope with the main tube-- point the scope at the top of a distant telephone pole or church steeple.
Without moving the scope, line up the cross-hairs in the finder scope with the same object. Once this is lined up you can use the small finder scope to locate objects in the sky.
Read my TIPS on my profile page.
Jul 14, 2010 | Citiwell International Orbitor 5500...
About a router I just bought
That "large phone chord" is actually an ethernet cable or RJ-45. Its very similar to the RJ-11 telephone cable but they cannot be interchanged. One is strictly for networking computers the other one is only for telephone.
here's a good video that explains how to hook it up, youtube has a lot of good videos on the topic of routers
http://www.youtube.com/watch?v=rEUAAiAIKbw&feature=channel
Dec 30, 2008 | Linksys Wireless-G WRT54G Router
DCT 646
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Dec 16, 2008 | Uniden DCT646-2 Cordless Phone
Telephone use for apc surge protector
Yes, you must run your phone line thru the BackUPS for it to properly protect telephone equipment!
Please read this document for further help.
Jun 16, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
