Question about Acer NSK8458AN Keyboard
There's water in my tail light, how can I tale them out?
  • asid
    asid Jun 20, 2011
    I fixed it
  • 274 Answers
From the inside of the trunk/ hatch you will see where there is anywhere from 2-4 screws holding them in. Once out, drain the water out of the holes where the bulbs go in. That is the easiest way, try not to break the seal of the lense and housing. Please rate if i was able to help!
Posted on Mar 30, 2011
Testimonial: "Thank's, I'll give it a try"
  • 11,896 Answers
There is likely a bad seal or a cracked lens. You can access the screws that hold them in through the rear hatch or trunk. Then pull out the bulb and socket and drain the water. Now you can use a silicone or epoxy to seal them up or purchase different lenses.
Testimonial: "Thanks "
  • asid
    asid Jun 20, 2011
    Thanks again
  • Nate Stansfield
    Nate Stansfield Jun 23, 2011
    ANYTIME! And thank YOU for using Fixya!
Brake lights signals not working
If the tail light goes out when the brake light goes on, you have a bad ground.
Apr 12, 2014 | 2006 Hummer H2
My left brake tail light doesnt work. It works only when my lights are off, but when my lights are on and I hit the brakes... it doesnt function. Ive taled to the dealership about this and they said I need...
They are right. The bulb has 2 filaments. One for the brake and one for the running light. One of the filaments has burned out. You only need to replace the bulb. The bulbs are inexpensive. It's just a maintainence thing. Not to worry all light bulbs burn out eventually. It's an easy fix.
Dec 29, 2010 | 2000 Jeep Grand Cherokee
The tale lights are not working. Need to find the fuse diagram...where can i find one
Your tail lamps are powered by fuse "F" (20 Amp) in the underhood Power Distribution Center. The same fuse runs your front "Park" lamps.
Dec 13, 2010 | 2001 Dodge Ram 1500 Truck 2WD
No tell tale.
water pump-
crack in the housing from sitting over the winter with water in it
Apr 14, 2010 | 2006 Mercury Mariner
Tale lights are went out
If both your tail lights are out odds are its your fuse.Look for blown insturment light fuse.
Apr 07, 2010 | 2001 Oldsmobile Alero
2007 dodge ram 4.4 beeps when i press the brake pedal but the tail light is out on the left side also. And when you turn on the left blinker it goes crazy fast and no light in the light assembly. Help?
If you have a beebing noise every time you press on the brake, it is because a tail light is burnt out. There are two filaments in each brake light. Therefore, when you turn on your hazards, it will appear that both tail lights work properly. The beebing warning sound is actually a feature that Dodge put in the Rams so drivers would know their tale light is out. Just replace the tail light bulb, and the beebing will automatically cease. To get the tail light housing out, you will need a torex screw driver. Also, you twist the bulb housing out as opposed to pulling it out. There are three prongs that twist out.
Jan 21, 2010 | 2007 Dodge Ram Truck
No tail lights or gauge lights
Hi. the fuse you are looking for is located on the bottom left hand side of the box. Its Number 4. I will post a picture of the entire box so you can see it.
Mar 23, 2009 | 1995 Ford Mustang
Right tale light won't work..can't afford a ticket
try running an independant earth wire.Tap into the original earth wire and bolt/screw added wire to the body.do this at rear tail light assembly joiner plug
Oct 11, 2008 | 2002 GMC Sonoma Extended Cab
1995 Ford Mustang
they use different bulbs for brake and tale !!
exchange the bulb and c it works if worke then replace the bulb if no then replace the fuse
Mar 10, 2008 | Acer Aspire™ T180 PC Desktop
Acer NSK8458AN Keyboard Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
