Question about Garmin StreetPilot c510 Deluxe GPS Receiver
When I turn the main screen on i get the following message - No detailed maps found that support routing. The Streetpilot cannot be used without them. Can you help?
    President:
  • 1,514 Answers
The solution to this problem for garmin nuvi satnavs is at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
While your satnav is not a nuvi I would expect that the solution would be the same since they're both made by Garmin.
Posted on Mar 31, 2011
No detailed maps found that support routeing the street pilot cannot be used without them, it is saying this on the screen when i turn the device on
There's information on how to solve this problem for garmin nuvi satnavs at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
Some of the menus are probably different on the streetpilot but the procedure should be the same.
Jan 19, 2011 | Garmin StreetPilot c510 Deluxe GPS...
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin c510 error message "No detailed maps found that support routing. The streetmap cannot be used without them" Don't have pin number! Solution?
You're unit is probably missing the gmapprom.img file (failed update maybe?).
Try contacting Garmin - if you've got registered maps they may send you another copy (although big file - 100+MB)
Aug 14, 2009 | Garmin StreetPilot c510 Deluxe GPS...
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
No detailed maps found that support routing the streetpilot cannont be used without them garmin streetpilot c510
Jan 31, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Maps are missing
Same here..the phone support sucks.. i am on hold right now for 20 mins and i am not sure if they have an answer!!
Jun 01, 2008 | Garmin StreetPilot c530 GPS Receiver
Error message on screen (read message below)
Did you tried to update your Maps? There are two maps inside your Garmin. Basemap which covers all highways and major roads and mapsource source which cover regular streets. Try reloading mapsource maps.
From the "Where to" menu select the little wrench and then select map and then select Map info. What does it say for Map Info?
If the unit is still under warranty, call Garmin and get a RMA. Return the unit to Garmin.
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
