Everytime I go over a bump or turn my wheels and go over a bump I can hear a really loud pop sound come from my front end. It sounds alot like a ball joint pop but I'm not completely sure.
    Genius:
  • 1,015 Answers
Depending on the age of the vehicle and if it is front wheel drive I would have the contant velocity joints checked. Thank you.
Posted on Mar 30, 2011
1999 ford explorer limited whining noise in front end
Whining noise is probably in one of the pulleys or belts. Probably the power steering. And the popping is probably CV axles.
Aug 02, 2012 | 1999 Ford Explorer
2000 Dodge Durango: Loud popping sound near front wheels when braking, or going over a bump, turning into or backing out of driveways.
That sounds like the ball joints. The midsized Dodge is notorious for bad ball joints because the factory used substandard parts. I would not wait to have it repaired. There are documented cases of the Dodges losing the front wheels because of ball joint failure. You need to have them repaired asap. The lower ball joints are usually the noisy ones. If you can afford it, have all four fixed at the same time, But be sure to take care of the lowers right away. Hope this has been of some help.
Dec 27, 2010 | 2000 Dodge Durango
My front end is making very loud noises every time
same thing thats wrong wth mine ur bushings r bad. replace ur upper and lower ball joint and dont no proper name 4 it but outer tie rod goes to bushing on wheel change it.thats what im trying to figure out how to change.good luck
Jan 07, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Squeaking sound from shock absorbers
ball joints won't squeak like that; they make a popping noise when they're bad. it is very common for shocks to get water in them and start squeaking, and it's usually a horrible screeching squeak. The only way to get rid of the squeak is to change out the shocks. Hope this helped.
Nov 28, 2009 | 1997 Ford Expedition
A noise coming from front end of my saturn is it my tie rods
The noise you hear could be the tie rod ends or several other front end items. Can you jack up the front end? If so then turn the wheels from side to side with your hands griping the wheel at the 9 and 3 oclock positions. if you feel freeplay or looseness you have to reach arround and place your hand on the outter tie rod end and see if the play is there or the inner tie rod end at the rack. I worked for saturn for a few yaears and we had ALOT of front struts that made a clunking sound over bumps. Don't forget the lower ball joints could be bad also. Check these by placing your hand on the bottom of the wheel and pushing and pulling on the wheel with it off the ground while checking the tie rod ends. Good Luck, Scott
Jan 05, 2009 | 2003 Chevrolet TrailBlazer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
