Need info on how to lock my wireless router from outsiders
  • billy reynolds
    billy reynolds May 11, 2010
    WHAT KIND OF ROUTER DO U HAVE
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
there should be in the router a sercity tab click it and then goto drop down tab and find WPA PERSONAL AND after you get this on the router should say WPA share key this is the pasword for the router put in what ever you like and hit save setting and this should make it so no one but the person with the wpa shared key can log onto your router
hope this helps you out have a good day
Posted on Aug 04, 2008
How do I make my Dlink wireless router secure
There are several methods for "Securing" your router. I'll answer in general first, and if you need more info, just ask. Here are the top three methods to make your Router "Secure":
1. Create a Password for the ADMIN access to your router. This ensures that no one can get to your router through your IP address, and make changes (like adding their own computer to your DHCP Table). Be sure and record this somewhere safe.
2. Along with this password, Create a "Passphrase/Security Code", and install this code in your Router's Wireless Settings. I recommend sixteen digits, mixed alpha and numeric (recommend using lower case alpha only).
3. Create a Table of TCP IP addresses which emcompasses ALL the devices you will be allowing access to this router. For added security, make your range OUTSIDE the default range. Example: 192.168.0.210 to 192.168.0.214. That would give you Five devices, and ONLY those five devices could connect (this is your own situation). Then set the "Number of Devices" to just "5".
4. There's actually a fourth step called "Locking it Down" to those devices ... but first get to the point where you can actually SEE these devices connected within the router's DHCP Table. GOOD LUCK!
Jan 11, 2015 | D-Link DIR601 WirelessN 150 Home Router...
Why cant i access wireless in my home or download
Can you verify if other devices can have access to the internet in your home? If you can access wifi connection elsewhere, then most likely your wireless router is not configured. You didn't specify if it ever has been. Router needs to receive the internet signal from outside the house and make it available through radio. Depending on the make and model of your router, you would need a hard-wire connection between your PC and the router. Then you need to configure it, assign a wifi name, security type and password for it. Write it down on a sticky label and stick it under the router because eventually this info gets forgotten.
Aug 27, 2014 | Microsoft Windows Vista Ultimate Edition
How do I lock the router for no outside use?
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 24, 2011 | Linksys WRT160N Wireless Router
Can my linksys broadband go out
What exactly do you mean by "go out"? As in drop a connection go outside? range of wireless? please post more info include model of the router and be specific on your question.
If you do mean: can it drop connection. Then yes, any router can and does, depending on settings model and actual broadband line, make sure you have a filter installed on the line so your phone doesn't interrupt the connection
Aug 31, 2010 | Linksys Wireless-G Broadband Router
How can i locked my router so that outsider will not access to my wireless router
You will need to access your router through the interface and enable security. Depending on the router you will have an option of WEP (less secure), WPA (more secure) or WPA2 (most secure). You will need to enter a name for in the SSID field (this is the name that will be visible to your wireless device), Enter a network key (write this down, you will need it later) and set the network authentication to shared.
Then when connect to the router with your wireless device it will ask you for the network key that you entered earlier. Now your wireless network traffic will be encrypted and not accessible without the network key.
May 20, 2010 | Computers & Internet
How do i lock my router from outside access
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Feb 16, 2010 | Linksys Wireless-G WRT54G Router
How do I lock my trendnet tew-652brp wireless router so my neighbors and others can't use the internet through it? I have changed all other passwords on it, but none seem to lock it from outside use.
to the router.
router.
Jan 21, 2010 | Computers & Internet
Came home from vacation went toconnect to router
to the router.
router.
Jan 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do I put a passcode on the router so only I can use it?
you want to secure the wireless network.
Is there any other computer connected to the router with the ethernet cable?
If not then you will need to connect the computer to the router with the cable.
check the ip address on the computer.open the setup page of the router. once you open the router setup page, you will find the option to make it secured.
Click Here for more info
Dec 11, 2009 | D-Link DI 514 Wireless Router (DI-514)
How you lock the wireles ruter
Are you trying to secure the wireless network ?
It is very simple.
Oct 13, 2009 | Airlink AR430W Wireless Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
