Question about Cycling
Right side pedal is "wallered
    Brigadier General:
  • 8,546 Answers
That would depend on the brand and design. A sprocket is literally a gear. A crankset is the combination of the crankarms and mounted gears. Bottom brackets join them within the frame.
http://en.wikipedia.org/wiki/Crankset
http://www.sheldonbrown.com/brandt/stuck-pedals.html
Pedals are replaceable.
A Bicycle Shop could help you decide what you need and select the proper size(s).
Posted on Mar 30, 2011
Pedal slipping
Chances are the right hand clutch sprocket is failing. You can replace just the right hand side or the whole drive hub assembly. I usually find if the right hand side is gone, the left hand side is not too far behind. I will provide a link for the product I am referencing. Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Feb 26, 2014 | Stairmaster 4600 Cl Cordless Freeclimber
Tip
Drive Hub Assembly Replacement for Stairmaster 4000PT Stepper
Stairmaster Stepper Drive Hub Assembly Replacement
  1. Remove the side covers.
  2. Remove the step chain retainers.
  3. Supposrt the pedal arm. Unhook the pedal arm return spring from the spring hanger. Lift the step chain up and off the clutch sprocket and lower the pedal arm to the floor. Repeat on the other side.
  4. Remove the snap ring from the left end of the drive shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  5. Remove the drive chain.
  6. Remove the sprocket and other small parts from the left side of the hub assembly.
  7. Slide the drive shaft to the right, out of the hub assembly. If you remove the right-hand clutch sprocket form the drive shaft, do not confuse it with the left-hand clutch sprocket.
  8. Loosen and remove the two remaining bolts and nuts that hold the hub assembly to the frame. Remove the hub assembly.
  9. Inspect the drive shaft, bushings, thrust washers, and clutch sprockets for excessive wear or pitting. Replace any worn components.
  10. To reinstall the hub assembly, carefull reverse the disassembly procedures. Be sure that the right- and left-hand clutch sprockets are positioned correctly; the wide shoulder of the sprocket should be facing away from the hub on both sides.
  11. Chain Tension. The drive shaft is mounted in an eccentric hub. Rotate the hub so the marked hole is in the 12 o'clock posistion, lining up four holes in th hub with the four holes in the frame. Use this hub position when reinstalling the drive chain since the distance between the drive and the transmission shafts is at a minimum. The hub is in the proper position when the drive chain has a total of 1" to 1-1/2" of play, up and down, at the slackest point in the chain. If it is necessary to increase the tension or tighten the chain, rotate the hub counter clockwise until the chain has proper tension.
  12. Reinstall the covers.
How to Repalce the Drive Hub Assembly on Stairmaster 4000PT
on Feb 25, 2015 | Stairmaster 4000PT Stepper
I have a 440pt and the left pedal is skipping down to the floor about every 5 seconds. If the issue is the hub assemble, do I have to change out everything or can I just replace the bearing, etc...?
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Sep 05, 2013 | Stairmaster 4400PT FreeClimber
Stairmaster 4000pt pedal slips
Jul 07, 2012 | Stairmaster 4600PT Stepper
From time to time a pedal will "pop" as it goes down. It seems as if either a chain has skipped on a sprocket or (I am imagining) that a pawl has slipped over a tooth somewhere. Becasue it...
Not rebuilt very well, was it?
These things are prone to break. You will have to disassemble somewhat to assess the situation. If the missing tooth or damage is not on anything visible, then it is inside the transmission box and you need a new transmission. Like owning a car, isn't it? I'm no expert on this machine, by the way, but you are exactly right about what the sound is, it is a slipping gear or chain. Look carefully for bent sprocket teeth, a sprocket that wobbles from side to side (lateral run-out), etc. If you can't find any damage, then it's probably hidden inside the transmission.
Feb 18, 2011 | Stairmaster 4400 PT Stair Stepper
My right pedal on my 4600 cl goes right to ground i belive the bushing is bad on the leveling arm the left side pedal is good and i nice and tight on the shaft where the right side was loose do u think the...
Dec 05, 2010 | Stairmaster 4600PT Stepper
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
I have a stairmaster 4400cl and the right hand pedal intermittently slips and drops to the floor. it only does this a few times every 5 minutes or so. when i put weight back on the left pedal and start...
Oct 17, 2010 | Stairmaster 4400CL Stepper
I need to know how to put a new oil gasket 1986 honda xl 100cc. is it as simple as taking out the bolts that hold it on and slide in a new gasket? Thanks
If it is on the right hand side of the bike then yes. Remove the clutch cable by undoing the adjustment nuts on the engine side of the cable and unhooking from the lever. Remove the nut on the gearshift pedal and pull of the pedal. Remove the dipstick. Undo all the nuts on the cover, and remove it. Locate the new gasket on the engine. There are 2 locating dowels so it should not have diffyculty staying in place. Replace the cover and clutch cable and readjust the clutch cable.
On the left hand side of the engine is a bit more tricky as the oil is not leaking past the gasket on the cover itself. There are 2 places where it can leak from. One is behind the drive sprocket. Remove the cover. Undo the nut on the sprocket. Bend back the tabs on the locking plate and remove the sprocket. Drive a self tapping screw into the shaft seal and pull it out with a pair of pliers. Drive a new on back in place. Also see this : http://www.fixya.com/motorcycles/t5649906-1996_yamaha_yz250
If the leak is from behind the alternator you will have to remove the magneto. This is diffycult as you need a puller to get the flywheel off the crank. Then the alternator assembly and only then will you be able to reach the shaft seal. This can be removed as per the previous link.
Aug 18, 2010 | 1986 Honda XL 125 R
Hi trying to re grease the pedal sprocket bearings on my Ross Rock Machine mountain bike. I got off the pedal arm on the right side but can't figure out how the left side comes off. The pedal arm looks...
Bottom brackets are sealed, removing the seal will have potential for damage. If it's making noise, replace it or better yet upgrade as a crankset. You'll have new crankarms, bottom bracket, chainrings with it. Unless you have the correct bicycle tools (not general automotive tools) you won't be able to pull your crank and even reach the seal for the bottom bracket. Click here for tools you need to do the job.
Jul 03, 2010 | Ross Rock Machine Aluminum Mountain Bike
Cycling Logo
79 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
