Question about Comfort-Aire EKTH15-150J Air Conditioner
I have a Heat Controller EKTH15-150J PTAC. Of lat,e toward the end of winter here in southern Missour,i the unit while in heat mode has been randomly blowing cold air. Often you can shut off the unit and let it sit for awhile and when you turn it back on it will come up heating again. A couple of years ago I replaced the control board that had been killed by a lightning induced power surge with a RSKP006 control board kit. It has run fine since, until the last few months. Sometimes I can put the unit into cool for a second and back into heat and it will blow hot air again, but not always. I can't find a lot of logic to its behavior. I have an electronics repair background, but not a lot of HVAC experience.
  • 3,361 Answers
Your problem sounds more like a reversing valve issue.
The reversing valve will tend to stick and not close completely causing cool air instead of warm.
Check the low voltage wires to the control board(usually orange) and the 24 volt signal at the reversing valve.
The r/v coil could also be intermittent.
When you switch the system to cool,then back to heat,the reversing valve is activating. That leads me to believe it is sticking.
Also check the defrost time on the board.
They are usually changeable from 30/60/90 minutes.
If not already set for 90,change it to 90 minutes.
Last but not least,observe the outdoor unit when it does this cool air thing.
If the unit has an ice buildup and is not defrosting correctly,that can be a sign of a bad defrost thermostat or a bad control board.
When the unit correctly goes into defrost mode it should also turn on inside heat strips to compensate for the cool air entering the ducts.
Posted on Mar 30, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
PTAC PDE12K3SB - No Heat
i think so may be the heating coils are not getting heat without power supply check out the plug in wire and whole supply.
Dec 18, 2007 | Friedrich Digital PTAC PDH12K35B Central...
Why is my PTAC unit so noisy in the winter months?
hi Jennifer.
this is all i could find.go to this link and see if it helps you to find out why.
Why is my PTAC unit so noisy in the winter months Google Search
Nov 18, 2017 | Heating & Cooling
I have a FEDDERS PTAC/HP -07B/09B/12B/15B. It blows cold air only. NO HEAT!
First of all check your unit model has heater system. And then
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 04, 2011 | Fedders Heating & Cooling
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
Charging a ptac
Either or, they both are the same ends but different routes..
Sep 08, 2008 | Amana PTH123B25AJ Heat Pump Air...
Will PTAC solve my problem?
Nope its a big room for 24000btu. the computation is 18sqm./ 1 ton. or 1.5 hp.
Mar 18, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
103 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Ottoniel
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
