Question about Whirlpool ET1MHKXM Top Freezer Refrigerator
I have a whirlpoon ET1MHKXMT0 refrigerator/freezer and NO ice maker. I find ice in the freezer on a regular basis. Where is the drain located and how do I go about unplugging it. It looks like a small resevoir in the back of the freezer but where could this be plugged and how do I go about unplugging it? Thank you.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
How do I get the icemaker to make ice
TROUBLESHOOTING ICE MAKERS.
Nov 23, 2014 | Refrigerators
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Icemaker not working
In order to keep your refrigerator's ice maker working properly, there are some components that will require routine maintenance and inspection. Some of the most common problems that can occur with your ice maker are the ice maker not making any ice, making too much ice and not shutting off, the ice tasting bad, ice cubes too small or discolored and ice cubes not ejecting from the ice maker. Checking your ice maker for potential problems on a regular basis will keep it operating efficiently.
1.Inspect the water supply line for any signs of cracking or crimps in the line. A pinched water supply line can keep the water from getting to the ice maker, resulting in no ice or smaller than desired ice cubes. Check to verify that the water supply valve is open enough to provide an adequate supply of water to the ice maker.
2. Flush out the water supply lines if you are noticing a bad taste in the ice cubes. This can be done by disconnecting the lines and running hot water through them. Turn on the hot water at the kitchen sink and place one end of the water supply line near the tap, holding it in place to allow hot water to run through it. Place the other end of the supply line in the sink to allow the water to drain through.
3 Reattach the water supply lines to the water supply and refrigerator. Repeat step 2 for the water inlet hose which runs from the inlet valve to the ice maker. If the water supply lines are old or discolored, consider replacing them with new water supply lines.
4 Check the temperature in your freezer to verify that it is getting cold enough. The freezer's temperature should be at 5 degrees and can be set with a control dial, normally located in the refrigerator compartment of your appliance. To test the freezer's temperature, place a cup of cooking oil in the freezer with a cooking thermometer sitting in the cooking oil. Allow the oil to sit in the freezer for 2 hours and then check the temperature.
5 Check the ice maker's shutoff arm to verify that it is operating properly. To work normally, the shutoff arm should be in the lowered position. Inspect the arm for anything blocking it or preventing the arm from moving freely. Lift the arm up to see if the unit shuts off in the up position.
6 Unplug the refrigerator from the electrical outlet and remove the faceplate of the ice maker's shutoff switch with a screwdriver, located on the ice maker. Remove the entire ice maker unit from the freezer by undoing the screws that are holding it in place. Unplug the ice maker from the freezer and take it out of the freezer to work on.
7 Remove the mounting plate on the top of the ice maker by unscrewing the screws and lifting it off the unit. Locate the shutoff switch, which has three electrical wires attached to it. The shutoff switch is located directly under the shutoff arm of the ice maker. Pull the electrical wires off of the shutoff switch with needle-nose pliers and label them so you know how to put them back correctly.
8 Inspect the electrical terminals for any rust or corrosion. Use an electrical testing meter to verify that the shutoff switch is working properly. You should get a reading of 0 or infinity on the meter. If the shutoff switch is not giving a reading, replace it with a new switch and reattach the electrical wires to the switch.
9 Place the mounting plate back over the ice maker and attach it with screws, then reattach the entire ice maker unit to the freezer. Plug the ice maker wiring back into the freezer and put the face plate back over the front of the ice maker.
10 Plug the refrigerator back into the electrical outlet and allow the refrigerator to run for a couple hours. Inspect the ice maker to verify that it is working properly.
Hope this tips would help you.
Good day! : )
Sep 06, 2011 | Refrigerators
Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
Oct 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker quit working
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 07, 2009 | Refrigerators
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water in the refrigerator portion...
the drain in the freezer is blocked with ice,unclog the drain by letting the whole thing defrost or take the back cover off inside the freezer and locate the drain hole and pour hot water over the drain and sponge up excess and repeat if it does it again after you unblock drain you need a defrost timer
Jun 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ET1MHKXM Top Freezer Refrigerator Logo
77 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
