Question about Kenmore 65234 Bottom Freezer Refrigerator
My freezer drain is stopped up. Where is it located and how do I get to it?
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
Water will not drain and builds up in freezer
clean drain and lower freezer temp
Dec 11, 2009 | Refrigerators
LEAKS WATER ON TOP SHELF OF UNIT
You most likely have a stopped up drain in the freezer. When the freezer goes into defrost, the water drains out and down the back of the unit. Into a pan located on top of or close to the compressor. You will need to unclog the drain.
Nov 17, 2009 | Frigidaire FRT18S6AW Top Freezer...
Freezer forming Ice on the bottom not draining water were is the drin plug can,t fine it
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 28, 2009 | Freezers
Ice build up in the bottom of the freezer
Your don't ask a question but you're headed in the right direction. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 02, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice build up dripping from refrigerator down to freezer
Jun 30, 2009 | Gladiator Freezerator Top Freezer...
Zanussi fridge /freezer
the drain located under the evap. maybe stopped up pour some boiling hot water into it and see if it drains underneath into the drain pan
May 06, 2009 | Zanussi ZEBF250W Bottom Freezer...
REFRIGERATOR dRAIN stopped up
LOOK INSIDE THE BACK TOP OF THE REFRIG. SEE IF THE DRAIN CHUTE IS THERE,IF YES YOU CAN USE A HANGER TO UNCLOGG IT.OR PULL OUT FROM WALL AND LOCATE DRAIN HOSE AND **** IT OUT WITH A SHOP VAC.,OR IF DRAIN IS NOT IN FRIG.REMOVE PANEL IN FREEZER AND THE DRAIN SHOULD BE IN THE MIDDLE BACK BOTTOM,IF FROZEN THAW IT OUT WITH HAIR DRYER,THANKS-MIKE
Mar 30, 2008 | GE Profile Arctica Stainless Steel Top...
Kenmore 65234 Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
