Acer aspire notebook monitor flicker - Computers & Internet
    Champion:
  • 232 Answers
THE LCD ITSELF MAY BE GOING BAD , TRY PLUGGING UP ANOTHER MONITOR TO ITS VIDEO PORT IF IT DOES THE SAME
Posted on Aug 04, 2008
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
When i type and or scroll my monitor flickers
its happen when the vga driver is not loaded or low memory
install the vga driver first to your computer
other wise upgrade the system memory
ok bye...............
Nov 10, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer 4715z monitor flickers
Hello Blue_shadow0,
Your monitor may be flickering because the connection of the LCD is loose on the motherboard. You would need to open up the laptop and check the connection or bring it to someone who can do it for you.
Jul 16, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Monitor flickering
Hi
Change the power cable if that does not work the power connector on the monitor may be faulty, Test the moniter on a different computer
Mar 28, 2009 | Acer Aspire 4315 Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Hi.. I am suffering flickering problem with my Acer Aspire 5920.
This is often a problem with the backlight on the LCD panel. If you gently tap the side of the LCD does it flicker more? If it does, then there is a loose connection in the LCD panel, and you might be able to get a comptuer shop to fix it, but it usually is expensive. If you don't mind using the laptop as a desktop, then get an LCD monitor and a USB keyboard and mouse, and you can use it as a desktop.
Jan 30, 2009 | Acer Aspire 3000 Notebook
My LCD monitor is blinking very frequent.
When the refresh rate changes then the screen will flicker. Change your refresh rate to above 75.
Here is how: Click on Start>Control Panel>Display>Settings>Advanced>Monitor>and you will see screen refresh rate. Change to higher rate.
Rate this solution.
Jan 09, 2009 | Acer Aspire 4315 Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
ACER 5630 LCD screen flicker
hardware poblem lcd or inverter problem
Oct 07, 2007 | Acer Aspire 5670 Notebook
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
