Question about Rheem Water Heaters
We have a 103 gal Commercial Water Heater Gas. The ignitor seemsto cycle several times before the unit will fire What could cause this to hapen?
    Master:
    Sergeant:
  • 500 Answers
Clean the flame sensor.its probably sooty its in the area of the burner it will have a semi stiff wire or 2 wires..
Posted on Mar 30, 2011
Testimonial: "After speaking with Technical Support I received the same answer"
  • mklooknum Apr 02, 2011
    Thank you so much. "ultrat"
    ____________________________________
    Alam clocks For Heavy Sleepers
    www.hot2sale.co.cc
    Macbook Pro Reviews
Insinkerator water heater w152 smoke from power switch
Disconnect(turn off the breaker) the electricity from the unit. There is a short that will cause a fire.
Cause of the short will require investigation
Jul 13, 2014 | Rheem 65 GAL ELEC Water Heater 6YR Self...
AO Smith BTH 500 ignitor keeps burning out,is my electronic control the problem?
I would report problem to AO Smith.
Also ask question on pro water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
If the igniter is not turning off, then that would explain early failure, and it would be caused by the control chipset
Mar 21, 2013 | A.O. Smith BTH-500A BTH-500A 130 Gallon...
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Heater when switched for gas operation will send spark to ignitor and ignite for approx. 5- 6 seconds and go off.Will do this 3 times and lockout?
Have you tried positioning the electrode closer to where flame is? That also senses flame to keep gas valve open, and if not sensing flame, with cause it to shut down. Clean it with a small brass brush, or similar, and make sure it's getting good flame from burner directed at it. Let me know if that helps. Do you by chance have a multimeter, or 12 volt test light for troubleshooting ?
Apr 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
May 30, 2009 | Water Heaters
Water heater in my 1988 minne has spark at ignitor but no gas has gas inlp tank
turn off LP tank valve. let sit for 5-10 minutes, then slowly open LP tank valve. opening the valve too quickly cause a ck valve to close. It's a safty in the event of excessive gas escape like a damaged regulator or hose. just barely crack it open and let the system balance. do not open suddenly.
Good Luck
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
The water heater will cycle 5-6-7 times with no probles then it fails ignition. The water heater is a rheem 50 gal power vent 2. It is about 2 years old.
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
Apr 13, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
61 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
