Question about Honeywell Heating & Cooling
Can I set my honeywell st699 timer to programme my heating and water at different times of the day on the twice setting.
  • 17 Answers
SOURCE: replacing Honeywell heating progrmmer
yep the wires will hook up to the same designations, just write down what color was connected where. You will need to set the thermostat up for your particular situation...gas, electric, heat pump, ect. The installation maunel is very clear on this aspect so you should not have a problem.
Posted on Nov 14, 2008
  • 16 Answers
SOURCE: cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Posted on Aug 17, 2009
SOURCE: how do i remove my st699 honeywell programmer from
Because there are no apparent screws to remove the front of this unit it can be very confusing if you have not done it before. Underneath and to the right hand side you will find a small notch in the plastic, it can be difficult to see when the unit is on the wall, using a small terminal screwdriver push upwards on the plastic tab which locks the front in place and with a slightly larger flat bladed screwdriver prise the front off bottom first then the two locking tabs at the top.
You will probably find that the back case is fastened to the wall with two screws.
Replacement is simply a matter of snapping the front back into the case.
Posted on Sep 22, 2009
milten1
  • 1304 Answers
SOURCE: can I upgrade my honeywell st699 programmer to a
it should be a direct replacement
Posted on Oct 05, 2009
  • 80 Answers
Yes.
Posted on Oct 07, 2009
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Can you replace a danfoss TP9 with a honeywell ST699
I believe the TP9 is a programmable thermostat.
While it appears the ST699 is a timer that connects to a thermostat.
So yes, they both control 230Volt boiler-and-pump. But there are differences.
Google search each item and include .pdf in search parameter to find product manual for each, and then compare wiring differences.
Nov 19, 2012 | Honeywell Hardware & Accessories
Hi I have a Honeywell st699 programmer for central heating and hot water. The only problem that we have is that we can not change the time on the clock. This means that we cannot set any programmes. Is it...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
Cannot set timer on central heating/water system.
HONEYWELL WEBSITE:
Go to honeywell.com
Jul 27, 2010 | Honeywell Heating & Cooling
I've just moved into an oldish house and there is a honeywell heating/water controller installed. its quite old and i cannot find any identifying marks on it. It looks like a st699, 2 on/off per day. I...
If you go to your local home depot, and get a new thermostat, it will come with different diagrams for wiring in the instructions that are pretty easy to understand. I hope this helps.
Nov 04, 2009 | Honeywell Electronic Programmable...
Cannot get central heating working,for honeywell ST6400 programme
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Replacing Honeywell heating progrmmer
Oct 30, 2008 | Honeywell Programmable Thermostat Heater
I have a honeywell ST699B controller for my central heating & water, i walked past it today and the light that indictes the water is on was illuminated. The water is set to come on once a day but not...
i have an st699 programmer its set to go on twice a day heating up but when the wife gets up after ive gone to work the timer is not at the correct time so no heating any ideas as new ones expensive to buy
Jun 25, 2008 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
