Question about Kenmore 44423 Side by Side Refrigerator
I have a recurring problem with my Kenmore side by side refrig (59652673202). Occasionally it stops cooling on both sides. When unplugged it seems to reset itself after a while (maybe a week) and cools again. The fans works and blows when this phenomenom occurs. Coils are clean, Help!
  • dm34598 Mar 30, 2011
    Sounds reasonable. Are there any more photos of the procedure you could provide? Sears Direct site is down, any idea of the cost?
  • dm34598 Apr 03, 2011
    I already ordered and received the overload relay. It is identical to what you described. When i openned the back rear of the fridge, i discovered that it is missing. It appears that the Sears Tech (who needed 2 visits to complete the repair last year) replaced it with a different capacitor and rerouted the wires. I will send photos shortly.
    Guru:
  • 262 Answers
Many times this happens when the compressor relay/overlaod starts going bad.
here is a link showing you the part which is attached to the side of your compressor. Without it your compressor will not run.Part number 4 on the diagram.The unit is not resetting itself but cooling down. The relay and or compressor becomes to hot to run and will shut down. Therefore when given enough time to cool down it will restart. Please read the couple of paragraphs on the subject below. Please post any other questions you may have.
click on the link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-59652673202/0582/0165000/M0312744/00015
I hear a clicking noise or freezer and refrigerator are warm
This is the most common repair for this issue.
Start Relay
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator.
Remove the lower rear cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this (Photo below). Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. Inspect it carefully for any burn marks, if it has any replace it. If not, most of the time it's ok.
. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. A 3 in 1 start relay can also be used as a substitution. Just make sure it is rated for the horsepower of the compressor. If you replace it and it doesn't work then the compressor is bad and you
Posted on Mar 30, 2011
  • Keith Drake
    Keith Drake Mar 30, 2011
    here is a link for repairclinic.com they have a one year warranty on all of the parts no questions asked.Around 16-17 dollars
    I use them for my buisness.
    Click on the link http://www.repairclinic.com/Shop-For-Par...
    The part is located on the side of your compressor. Unplug the unit,take off the lower back panel.
Side by side refrig. for a few months both sides would stop cooling and the frig side wouldnt be cold at all but the freezer would be almost as cool as a refrig (this was after I unplugged it and then...
it may have a stuck or faulty defrost timer... find it and you should be able to adjust it to make the fridge come on.... remove it and replace it yourself... simple plug and play so to speak!
Jul 19, 2011 | Kenmore Refrigerators
Fridge not cooling or freezing
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Kenmore 52673 Side by Side Refrigerator
Freezer has stuck in defront and stops cooling
Yours has a defrost timer board inside the fresh food compartment and behind the control panel. The only way to stop this is by replacing the board. Part number 4388932 and here is a view of its location inside the fresh food compartment. Just be sure the power is unplugged while working with board.
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
KSRG25FK Control Panel
Thanks, Sea Breeze
Aug 17, 2009 | Refrigerators
My kenmore side by side/ model 55771/ is having the same problem.
Is the fan running by the compressor and are your coils clean under refrig ? also make sure the cardboard panel is on the back of the refrig .
Jul 22, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Will not cool proper on fridge side
THIS IS A DEFROST PROBLEM EITHER THE THERMOSTAT OR DEFROST TIMER IS BAD! THE THERMOSTAT IS LOCATED BEHIND THE WALL IN THE FREEZER COMPARTMENT ATTACHED TO THE COILS TO KNOW IF ITS BAD IF WILL HAVE A RAISED SPOT ON THE BACK LIKE ITS BUSTING OPEN CHECK THAT
Apr 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/freezer has stopped cooling
Sounds like you need a new relay for the compressor. Unplug from wall and check the compressor see if realy that is attached to pins on compressor, is burnt.
Apr 05, 2009 | Kenmore 53082 / 53084 Side by Side...
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Dec 17, 2007 | Refrigerators
Kenmore 44423 Side by Side Refrigerator Logo
188 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
