Question about Samsung SyncMaster 920WM LCD Monitor
ANALOG PROBLEM:NOT OPTIMUM MODE - Samsung SyncMaster 920WM LCD Monitor
  • 75 Answers
U CAN CHANGE MAIN BOARD IT WILL SOLVED, BN94-00527C PART NO,
Posted on Mar 31, 2011
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
Not optimum mode Recommened mode 1280x1024 60hz while monitor is on in between it shows this message then when i press enter it go and it will come again in a minute please give me a good solution i am mad...
right click on desktop as in your screen and click on personalize and click on change resoltuion
change to your resolution to 1280 x 1024 and then click on monitor tab and change the refresh rate to 60 hz
May 19, 2010 | Samsung 19IN ANALOG/DIGITAL 1000:1 5MS...
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
NOT OPTIMUM MODE
Solder a 50 ohm precision resistor between pins 5 and 6 of the Novatek NT68F63LG
I had this same problem on 3 Samsung 710N displays and this fixed the problem.
I have read others have also been successful but the value of theresistor was slightly different in some cases. I would start with 50ohms as that seems to be a common value fixing most displays.
Here is the reference URL to the ORIGINAL person that solved the problem.
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
Jan 28, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Floating window
HOW MUCH MEMORY DOES THIS COMPUTER HAVE
THIS COULD BE THE PROBLEM DO YOU EVER GET VIRTUAL MEMORY ERRORS
Jan 14, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 920WM LCD Monitor Logo
199 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
